Wedge TR7/TR8 seat question
Cosmo
Hi,
I have a TR8 in the shop here and can not for the life of me figure out how to recline the seatback. There are no obvious handles, the only handle is the lower one, below the seat to move it for and aft....whats up?
Thanks
Pete
should be a chrome handle on the left side at bottom of drivers seat,pull up and wiggle seat back and forth. Make sure the seat is not shoved all the way back to the R bulkhead.If no handle use TR6 window or door handle,it will fit,none of these?,then vise grips on the square black rod. Be carefull a big guy can break the seat back,....believe me.
Yup.. Rocks is right. I had my seat welded twice before I found a good non repaired used one. And.. you don't have to be a big guy to break it though. When you are in and you need somthing out of your back pocket, and push your feet on the floor, you can break the seat from the pressure. When you get out of the car, don't push on the top corner of the seat.. it will break. To add.. these seats are extreamly compfortable too for being 30 some years old, arent they /ubbthreads/images/graemlins/smile.gif
Paul
When I got my 7 the seats had been swithched right to left. This put the seat back levers on the inside next to the tunnel rendering them nearly unusable. Don't ask how long it took me to figure this out as I had no experience to go on. I agree that the seats are comfortable all things considered. Mine happen to have been done in leather at some time and I find that makes for added comfort over vinyl and more durable than cloth.
GBRandy Wedge TR8 [TR7] Seat Bottoms Triumph 8
GBRandy Wedge TR8 [TR7] Seat replacements Triumph 6
T Wedge TR7 / TR8 seat question Triumph 11
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
A Wedge TR7-TR8 brake rotors Triumph 17
GBRandy Wedge TR8 [or TR7] Fresh Air Intake Seal - help Triumph 8
johnrip Wedge tr7 tr8 alloy wheel tires Triumph 3
GBRandy Wedge TR8 [TR7] dash & switch pieces Triumph 1
S Wedge steering gear rack on a tr7 and tr8 Triumph 4
I Wedge Wheel measurements for a TR7 or TR8 Triumph 2
toysrrus Wedge TR7 & TR8 "BIG" write up: Triumph 14
swift6 Wedge TR7 TR8 DVD... Triumph 8
tr7andtvr Wedge TR7 or TR8 Master Cylinder Triumph 7
T Wedge TR7 manual rack into TR8 Triumph 9
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
T Wedge TR7 & TR8 bumpers / doors / dash parts interchange Triumph 4
T Wedge TR7 & TR8 doors interchangeable? Does year matter? Triumph 2
philman Wedge tr7/tr8 brake differences Triumph 2
Radford Wedge This just came over on the TR7 TR8 list I'm on. Triumph 0
1 Wedge TR7 and TR8 Engine difference Triumph 9
T Wedge TR8 TR7 windshield replacement Triumph 4
T Wedge TR7 or TR8 A/C drier Triumph 0
V Wedge April Issue AUTOMOBILE: GROUP 44 TR6, TR7 and TR8 Triumph 0
T Wedge Black paint under doors on TR7/TR8 Triumph 5
E Wedge I need some TR7 and TR8 Owners to sound off! Triumph 7
philman Wedge TR7/TR8 LSD Gear Triumph 0
J Wedge tr7 - tr8 throw out bearing carrier Triumph 7
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
mctriumph For Sale Tr7 engine Triumph Classifieds 2
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
