Wedge TR7 engine problem
johnrip
Thank you to those who replied to my hardly running engine, that occured overnight. I have the compression numbers. 110, 135, 140, 110. What should these be? I have no blue smoke, I have no coolant in the oil, and no leaks. The engine still barley idles, runs better at higher RPM, but is hesitant and some backfiring. Good spark, dry plugs.
Dale
Compression #s don't tell a full story, but as a rule I look for consistency. So 110#s on all 4 might be better than up and down like we've got. What do you find under the distributor cap? The cam chain on the 7 is relatively short lived and could concievably get so loose as to skip a tooth. Cam cover is fairly easy to get off and allow checking of clearances. It is a frustrating stumper that this occurred while the car was parked, but once you get it figured out it might seem more logical. AAR don't despair, we've all been there and survived to enjoy another drive and you will too. Do you have a service manual for your car? When my TR7FI died it took several weeks of phone calls and research to diagnose and 15 minutes to fix. Good Luck and God Bless
johnrip
johnrip
Thank you for responce. My mechanic is all concerned about the compression numbers...Do you know what they should be??
johnrip
johnrip
I have good spark, and the ignition seems OK. I have the lucas distributor, not the one you have on your FI car.
jessebogan
The reality is that compression test numbers are just that, numbers. Like was posted above, consistancy is what you are after. There are so many variables that can affect compression test, i.e. cranking speed, whether or not the engine is warmed up, throttles open or closed, etc. At this point, if your mechanic really has his knickers in a twist, a leakdown test might be in order. Still, it is HIGHLY unlikely that a mechanical fault developed overnight. Far more likely you have developed a carb or ignition fault, and that should be able to be diagnosed by a straightforward process of elimination.
tdskip
If the ignition is good then it sure seems like carb would be the focal point. Compresion figures etc can wait. I don't think those numbers would prevent the car from starting and running well.
johnrip Wedge TR7 Engine Problem Triumph 5
mctriumph For Sale Tr7 engine Triumph Classifieds 2
T Wedge TR7 engine, need help identifying part. Triumph 5
A Wedge SU on TR7 Float Level Engine Angle Triumph 10
M Wedge TR7 Engine, transmission and more to go Triumph 0
B Wedge TR7 Engine Swap Triumph 12
johnrip Wedge tr7 engine idle low RPM bounce Triumph 3
johnrip Wedge TR7 engine Rebuild Triumph 2
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
YankeeTR Wedge Hmmmm...Engine problems with free TR7.. Triumph 18
1 Wedge TR7 and TR8 Engine difference Triumph 9
johnrip Wedge TR7 Engine Serial Number Triumph 2
S Wedge TR7 Engine Woes Triumph 11
J Wedge TR7 engine swap Triumph 17
Hegg Wedge TR7 Engine and Performance Triumph 33
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
