Wedge tr7 clutch linkage problems
MDCanaday
In responce to a question asked by Dale on a prior topic, there is a cure for the tr7 dragging clutch blues. Drop the slave cyl. out of the way, with your handy migwelder add 1/8in to the release rod end. Test fit for proper free play and repeat if needed. when it is tight ,dress the end and lube it a little before re-assembly. I have done this on several 7s and the results have been great.Just take care to make the end as smooth as it was when you started.
MD (mad dog)
glemon Wedge TR7 Fan Clutch Triumph 5
johnrip Wedge tr7 clutch bell housing bolt? Triumph 4
T Wedge TR7 fan clutch worth anything? Triumph 1
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
johnrip Wedge TR7 Clutch Throw out noise? Triumph 1
S Wedge Now TR7's clutch is stuck!!! Triumph 11
S Wedge TR7 Clutch Problems Triumph 2
S Wedge Clutch Problems - TR7 Triumph 4
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
