TR6 TR6 engine rebuild. Too tight?
I'm beginning to think that too. I used Creakote on the tappets too and seem to spin much easier. Also in the timing cover where the chain tensioner rides.
Just some background info:
The most common, and cheapest rings are straight cast iron. They do not have a perfect contact surface, so the cylinder bores must be prepped by honing to a relatively coarse cross hatch finish. This rough finish speeds lapping the face of the rings to achieve a perfect seal. Because of this, cast iron rings have a relatively long break in period...like several thousand miles. A side affect is the rough cross hatching increases the drag between pistons and cylinder. I bet these are the rings you used.
The next step up is moly faced rings. Molybedneum (spelling) rings are pre-lapped in a hardened steel cylinder during manufacture. Because the face is much better prepared, the cylinders should be honed to a mirror smooth finish. Moly rings will break in within a hundred miles of running...and if a break in procedure is used, they break in in a matter of minutes. The side affect of having rings and bores this smooth is there is little friction between the piston and cylinder...so the engine will easily spin by hand after assembly, compared to your build.
Then there are the specialty rings...chrome rings in iron bore, chromed bore with iron rings, nickel plated aluminum bore...and on and on. All the newer designers use a near mirror bore and pre-lapped rings to reduce break in and friction.
Anyway...most guys rebuilding our TR’s are still using the old school iron rings on a rough honed bore...so a lot of friction after the initial build is to be expected. The end result is just as good as modern engine builds, but you will have a longer break in time.
One of the nicest features of the TR3 design is easily replaceable and relaltively inexpensive cylinders.I use only cast iron rings in my vintage bike motors but cylinders are rare,softer cast iron than modern bores and I would rather have the rings wear ,not the cylinders.They are also more forgiving to a not perfectly round bore.Burnishing the final 220 grit hone with a few qiuck passes by hand of some 400 or a burnishing brush nocks the peaks down but like John mentioned longer break in is required .
The only problem I have ever heard of with the three piece oil rings was incorrect install with the spring spacer not set right.
Im always amazed when top fuel dragster guys replace pistons and rings and blast a full out run.They have pistons with gas ports to pressurize the rings.
Someday I may find out whats in my TR3 as the short block came to me rebuilt.12k now,hopefully good for another 100k.
Arnt these just the coolests motors!
Tom
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
hondo402000 TR6 TR6 Engine rebuild in progress Triumph 14
hondo402000 TR6 TR6 Engine rebuild and getting uneasy feelings Triumph 36
hondo402000 TR6 latest Part for TR6 engine rebuild Triumph 6
I TR6 TR6 engine rebuild suggestions Triumph 8
hondo402000 TR6 TR6 Engine Rebuild parts on order Triumph 30
M TR6 tr6 engine rebuild Triumph 6
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
2wrench TR6 1974 TR6 Engine Rebuild and/or Repair Triumph 26
G TR6 $4600 for TR6 engine rebuild? Triumph 9
D TR6 Help with tr6 engine diagnosis Triumph 11
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
R For Sale TR6 Parts huge collection and Engine/Performance Parts Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
D TR6 Tr6 engine dimensions Triumph 2
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
M TR6 TR6 how the engine works Triumph 7
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
B TR6 TR6 Engine leaks, jacking questions Triumph 9
R TR6 TR6 engine rebuilt Triumph 52
SkinnedKnuckles TR6 TR6 Engine Bearings Triumph 12
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
M TR6 Free TR6 Engine! Triumph 4
ScottTR6 TR6 74 TR6 Engine Bay repainting Triumph 16
hondo402000 TR6 Painting TR6 engine bay in progress[NOW] Triumph 14
hondo402000 TR6 TR6 Engine pulling process Triumph 20
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
hondo402000 TR6 Pulling TR6 Engine Triumph 31
I TR6 69 TR6 engine suggestions - cause for burnt valve? Triumph 5
kodanja TR6 TR6 Engine in Ct anyone? Triumph 11
TR6oldtimer TR6 The TR6 engine is now alive Triumph 4
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
swift6 TR6 Teardown of a 150k TR6 engine... Triumph 4
Mike_Roe TR6 TR6 Engine Mods Triumph 8
TRnorwegian TR6 Japanes TR6 starter engine - good idea or bad? Triumph 21
T TR6 TR6 engine into TR4 Triumph 15
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
T TR6 TR6 engine replacement options ? Triumph 59
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
N TR6 Desired TR6 engine coolant temp? Triumph 7
E TR6 TR6 Engine Re-Build Candidate? Triumph 11
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
AltaKnight TR6 TR6 engine "freshening" Triumph 2
E TR6 TR6 Camshaft Install - Engine In Triumph 10
