The best webbing is seat belt material.It takes some extra time but is worth the effort. Do the rear holes first, take a small nail ,heat it, and snell a small hole in the belt for the screws.Next do the front bar(all sticks up in position!!)the belt should be firmly tight on both sides.Then finish up the holes in the middle bars by slideing the belt so you can see where to snell the next hole.
On the tr4 once the front steel strips are in the top you gently tap them under the top moulding so they are seated, the strech the top to the rear and locate where the snaps need to go for proper fit. do this with the frame in the relaxed position so that when you bring it up the top is tight(but not tooo tight)
Dont open up a cold one till this job is done, beer and vinyl dont mix!!!
MD(mad dog)
