TR4/4A TR4 Handbrake - Cable Support
Mark_Barton
Does anyone know where I can get hold of the brackets shown here that parts 32, 33 and 34 go through, at either end of the cable part 30? I'm planning a handbrake overhaul, and the front support bracket is looking a little the worse for wear (the cable pulled out of it last time I needed to give the handbrake a good tug!).
I called Moss, and they don't appear to supply the part - at least not as part of the handbrake assembly. TRF and VB don't appear to do much on handbrakes at all. Does anyone know of anywhere else I might try?
Hi Mark-
Welcome to the forum. You sure you need the brackets themselves? I don't believe they are separate pieces, they are actually part of the frame. Here's a pic I pulled off the net showing the front bracket. If you are actually missing them, that suggests some frame problems too? If you need them, I think you will need to fabricate the mounts as I doubt they will be available separate from an entire frame.
Randy
Thanks Randy, that helps. They're not missing as such, but the front one isn't a solid as it might be - I pulled the lever fairly tight, and the cable bent the bracket before popping out of the channel.
I'll get it up high enough to have a proper look at the weekend - hopefully it just needs a bit of extra support, and isn't a sign of a rotten frame!
It certainly does appear that those brackets are welded to the frame, which in that case, Tony at Ratco should have them, as they would be supplied with the frames he builds. Since your on Long Island, you can always stop by at one of the tech sessions we have at Ratco almost every Saturday morning. We can take a look at what you've got there and get things fixed up for you. I have a feeling you may have problems with the cable itself or some other part of the mechanism, as those brackets just hold the sheath in place. There shouldn't be a lot of force exerted in those areas.
But, if you need a new bracket, I'm sure we can rig you up with one.
Thanks Art, I will make it one of these weekends! Just need to come up with a good excuse to drag myself away from my better half at that hour on a Saturday. I'm not a morning person :laugh:
The sheath and cable both need replacing too; the cable's pretty much seized in there, which is why pulling the lever is pulling against the existing bracket.
T TR4/4A TR4 Handbrake Triumph 1
Alan_Myers TR4/4A TR4 gearbox dimension? Handbrake lever spare? Triumph 9
tr6nitjulius TR4/4A TR4 $100K Triumph 1
mctriumph SOLD!! Re-built Tr4 engine Triumph Classifieds 0
JCL TR4 TR4/4A TR4 Head Seeping Water Through Intake Casting Triumph 13
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
scottkilpatrick TR4/4A Recommended brake pads for 62 TR4 - Triumph 2
C TR4/4A New TR4 tuning Triumph 21
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
C TR4/4A New 1961 TR4 questions Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 11
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
