TR4/4A TR4 Downdraft install Latest...
F1LOCO
TR4 Downdraft install up-date...
Man v. Machine...12th round...Man wins...
Thanks for all the suggestions and help. Thought the cold chisel was going to be futile. Have some scarring, but filled it in with epoxy putty and will sand off tomorrow b/f a good rinse and Hylomar sealing...Hopefully it should all be ok as most of the scarring is further in:
So for those who want to embark on removal and insertion of the original TR4 downdraft tube, tips I've learned:
1. Remove the fuel pump - it's a must. Be ready with a capped fuel line and extra clamp as it is lower than the tank in the rear and will continue to pour after disconnection from the pump;
2. Get a compressor driven 3/8" drive rachet and self tapping screw;
3. Be patient as it will take forever at 2-3K RPM to go through the plug - maybe 5 minutes...Once it grabs go in a couple of threads but still need to be able to grab the head of the screw...
4. Get a flat notched nail puller - note pry bar is too curved, not notched and difficult to work;
5. Grab the head with the the notch of the nail puller and pry against the block, then insert a 1x.5" block of wood against the block bw the block and pry bar and pry again, and out it should pop.
Below is a pic of the nail puller I got:
Oh yeah, and lots of beer...it helps and makes the Indian dance at the end all the much better... Cheers...
tr6nitjulius TR4/4A TR4 $100K Triumph 1
mctriumph SOLD!! Re-built Tr4 engine Triumph Classifieds 0
JCL TR4 TR4/4A TR4 Head Seeping Water Through Intake Casting Triumph 13
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
scottkilpatrick TR4/4A Recommended brake pads for 62 TR4 - Triumph 2
C TR4/4A New TR4 tuning Triumph 21
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
C TR4/4A New 1961 TR4 questions Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 11
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
