TR2/3/3A TR3 bare shell weight
59Rob
More research for the inevitable restoration. Two questions, one, once you have it down to a bare shell how do you guys lift it off? it looks like it would be fairly light but I've already had two back surgeries so I would prefer to use brain over braun and would prefer not to wreck my friends either.
The second question is in how you work the bottom of the pan? it's not a good candidate for a rotisserie, do you just make a dolly to sit it on and get at as best you can?
I used an engine hoist to pull reinforced tub off my 56 TR3, and put on rotisserie for body work. Some pics on site in signature below. If you want more just let me know. I've got lots. Cheers, Mike
Thanks Mike, I didn't think it would hold up on a rotiserrie, I see a brace across the inner fenders and one for the doors, was that all the bracing you had to do?
I do have a lot of questions, I'm trying to pick away at them while I finish another resto so I can get at it when the time comes.
Cheers
When I took the tub off of my TR4A, my wife and I were able to lift it relatively easily. But I rigged up some blocks and tackles to the garage ceiling, because it ended up going on and off a few times, and that was I was able to do it myself.
I put lashing straps around the tub and then around the tracks of my 4-post lift. Then I lifted it off, rolled out the chassis, and rolled a dolly under the suspended tub. It sat on the dolly for years and I am finally getting around to working on it. Most everything else is done enough to put a car together.
I used lots of kids...
Bracing was only at doors. Shell was pretty good shape overall, and nose was on to provide support while lifting off body. Let me know if/when you want more info. Cheers, Mike
I weighed my TR4A body shell when it was off the frame. If I remember correctly it was in the 400 pound range including all the bracing and external supports that I had welded on.
I used lots of kids too.
Thanks for all the replys guys!
I used the cherry picker much the same way lifting my 48 chev pickup cab onto it's frame. I wasn't sure how I could make that work for the TR in terms of attaching points but clearly there is a way so I'll figure it out. At 400 or so pounds I don't really want to lift it by hand. A 4 post lift sure would be handy for this, getting one at some point is in the plan but it may not be in time for this. My kids are busy with their kids so it's not that easy to get them over, but it's a great idea if you have a house full of them.
Kleykamp TR2/3/3A Need either short block or bare block for TR3 Triumph 1
luke44 TR2/3/3A TR3 Body Stripping Bare QuikStrip Allentown Triumph 25
G No directional signals or brake lights on 60 Tr3. Triumph 0
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
RichB4493 TR2/3/3A Rare “TR3” spotted on safari Triumph 3
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
jfarris For Sale Original Style TR3 Luggage Rack Triumph Classifieds 0
jfarris For Sale TR3 early used fan $25 + shipping Triumph Classifieds 1
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
IdahoNuke For Sale Free TR3 Seats Triumph Classifieds 0
T Wanted Wanted TR3 rust free nut & bolt restoration Triumph Classifieds 12
R TR2/3/3A 1956 tr3 value? Triumph 7
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
D TR2/3/3A Black TR3 Triumph 20
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A The TR3 is up and running again.... Triumph 7
S TR2/3/3A Battery box for a triumph tr3 Triumph 5
J TR2/3/3A TR3 age Triumph 4
G For Sale TR3 original metal air filters Triumph Classifieds 0
G For Sale 1960 TR3 fitted black cover. Triumph Classifieds 0
S TR2/3/3A tr3 sat all winter Triumph 15
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
W TR2/3/3A TR3 Seat Belts Triumph 10
R TR2/3/3A TR3 Timminge Triumph 11
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J SOLD!! TR2 TR3 Tie Member Triumph Classifieds 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
J For Sale 1958 TR3 Partout Triumph Classifieds 13
