TR2/3/3A tr2 muffler clamp
sp53
I noticed as I am prepping the tr2 frame that the center muffler clamp must be something I have not seen. There is only one hole around the area where the muffle fits. Would anyone out there have a picture of the original bracket? I cannot seem to find any information other that they are not available.
steve
CJD
Post #42 in here has a pic:
If I remember, is uses rubber bushings around bolts on each side of the tunnel to isolate the bracket.
S
sp53
Yes that is what I thought at first, but my frame only has one hole drilled for it. I found that Rimmer brother has a picture of the early Bracket, but the part is not available. I could drill another hole in the frame and use a tr3 bracket or maybe a tr4. I did want to keep it original, and I could make one --kind of-- out of an old tr3 bracket I have. The original clamp was probably not working too well and that is why they change it.
steve
CJD
Interesting. PN4 looks similar to what I have, but the horizontal bar crosses all the way across. In your set-up you would get vertical support, but it would have no side to side support. The header pipe is solid mounted to the engine, and comes all the way down to that bracket. I had to heat my header and bend it slightly to get it centered in the cruciform. If you get the header pipe centered, then that support would not move very much. If it is off, then the more support you have at the clamp, the better. I guess, when I think about it, if the header is off, then even the best clamp is not going to hold it in position. Take you time to line up the pipes and I think any of the clamp supports will work, even what you have.
So, you have to decide if you want to keep it original or change to a later clamp support system. Only the very hard-core buffs would ever know, as the only sign outside of the cruciform are the bolt heads!
S
sp53
From what I can tell you probably have part# 12 in the upper photo for the main bracket that is what is commonly used later. In the lower picture part #10 appears to be the elusive tr2 bracket. This would match the single hole that is drilled in my frame.
My thoughts are the part# 12 would be superior because it bolts to the frame twice and would suspend the bracket better in the center. I am going to call TRF and see if they might have one.
The picture that Rimmer brothers show has the rear and the center clamp together, I think. This makes it difficult to separate the two brackets.
steve
CJD
In the Rimmer part breakdown above, mine is a little different from both of those shown. In the illustration above, the whole clamp is supported by a single strap, which would only support vertical movement. It's interesting as you watch the evolution of the support for that clamp. pt#10 must have been first...then pt#12 was an attempt to beef it up.
On my car, TS52xx, there are grommets going through the frame on each side, and no strap. Mine was apparently the next iteration, giving the clamp side to side support.
jfarris
Steve,
I ran into the same thing with my early 56, no hole in the frame on the motor/tranny side. I put the rubber washers on that side with an "elevator bolt" to hold them to the bracket. The outside had a hole in the frame and bolted nicely as per parts diagrams. The thing is wedged in so tight it doesn't rattle an more. I just couldn't bore a hole through the frame (probably couldn't have with everything in place anyway).
Good luck,
Jim
jfarris
Steve,
I used Moss part #812-020 Bracket $31.99
Good luck,
Jim
S
sp53
I dug through my old parts and learned more about the parts for the tr2/earlytr3 muffler clamp that I could not figure out. There is an extra hole drilled into the lower trans section to hold a vertical strap. That way there is only one hole in the frame and an extra hole in the mount to hold a rubber vertical hanger.
Steve
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
