TR2/3/3A TR-3 hard to start, but runs well once started
sammy
Member
I have a TR3 and I am puzzled. I have rebuilt carbs and electronic ignition. It cranks well, but doesn't want to start. I have tried choke on and choke off. It typically won't start with a cold engine without starter fluid. Once started, it runs well and will fire up once warm.
Does anyone have any ideas on where I should look and what may need adjusted?
Thanks for your help.
Could be many things, but a few that come to mind are,
Low compression. Either from worn rings, valves/ seats, or if there's a problem with the fuel system, from the cylinders getting washed down with fuel.
Next thought would be a weak coil, but there are usually more symptoms that go with that.
Or,possibly timing is off. Have you checked it lately, and also have you checked the mechanical advance mechanism in the distributor? It it's not working/ stuck, that coud cause an issue
Also, the carbs might need adjustment. If they're outta whack, it's an issue.
Just some ideas.
Definitely start by making sure the choke pulls both jets down by the same amount.
FWIW, I had the same symptoms and solved them in the short term by losing the electronic ignition. Had several other components fail a few months later, so they may have been the root cause, but it started fine with points installed.
Hard starting cold is likely caused by not enough fuel, especially if ether gets it going. I'm with Randall...concentrate on the chokes...
John
I richened the mixture a bit and found out the rear choke wasn't opening all the way. It's still a bit slow to fire when cold, but nothing like it was before.
PD
I thought all British cars were hard to start :p
On a serious note, do you think the fuel lines are clogged at all? they might be if your TR-3 has been sitting for an extent of time. My Spit sat for 15 years when I first started tinkering with it. We were getting spark but no fuel, so I got an old brake cable and fed in through the fuel line to push all the gummed up crud out.
K Hard Start, runs poorly when cold Spridgets 10
L T-Series Hard to start MG 11
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR2/3/3A Hard start questions.... Triumph 4
D Hard start Triumph 4
J '92 VandenPlas Hard to Start Jaguar 9
V hard start when cold Austin Healey 7
ronzet MGB Hard to Start 1966 MGB MG 4
don62 Hard to start when hot! MG 8
W Hard Start 2 Jaguar 3
S Hard to start MG 7
A Spitfire 78 Spitfire hard to start Triumph 9
Nunyas And now the subject we all love... The Hard Start. MG 30
G TR6 TR6 hard to start after running hard Triumph 5
B MGB Brakes scrapping sound from rear brakes on hard left or right turn. New wheel cyl, drums shoes ? MG 2
W Spitfire Rubber seal for hard top Triumph 0
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Healey Nut BT7 Panhard Rod Austin Healey 28
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
Healey Nut Good hard top on flea bay Austin Healey 6
W Spitfire Hard Top rubber Triumph 5
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
D General TR Hard lessons learned Triumph 4
Rut TR6 Hard top finisher Triumph 1
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
1 MGB 1966 MGB hard shifting into 3rd MG 1
TomMull Wanted TR3 Hard Top Triumph Classifieds 11
RAC68 Top Frame, Hard to Weld Austin Healey 13
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
