MGB Hard to Start 1966 MGB
ronzet
HELP.....Once started the car runs great BUT getting it to start is a real pain. If I coast and pop the clutch it starts immediately. Any suggestions :square:
Platinum
Battery voltage? Bad ground?
Usually ya can't get yer hand off th' key fast enuff if the iggy circuit is in good nick.
More detail, Ron!! Points in good trim?
ronzet
ronzet
Hi Doc,
I have been working on it and you are right. It was the battery cable to the starter solinoid. VERY rusty.
Thanks for your help, Ron
Platinum
Sheesh.
You KNOW better! :jester:
ronzet
ronzet
Doc,
Actually I do....
My wife decided that she was tired of my complaining about how hard the B is to start.... sooo, she took it upon herself to post this question.... I was in the garage working on the B wrestling with the battery cable at the time...
L T-Series Hard to start MG 11
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR2/3/3A Hard start questions.... Triumph 4
K Hard Start, runs poorly when cold Spridgets 10
D Hard start Triumph 4
J '92 VandenPlas Hard to Start Jaguar 9
V hard start when cold Austin Healey 7
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
don62 Hard to start when hot! MG 8
W Hard Start 2 Jaguar 3
S Hard to start MG 7
A Spitfire 78 Spitfire hard to start Triumph 9
Nunyas And now the subject we all love... The Hard Start. MG 30
G TR6 TR6 hard to start after running hard Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
Healey Nut Good hard top on flea bay Austin Healey 6
W Spitfire Hard Top rubber Triumph 5
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
D General TR Hard lessons learned Triumph 4
Rut TR6 Hard top finisher Triumph 1
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
1 MGB 1966 MGB hard shifting into 3rd MG 1
TomMull Wanted TR3 Hard Top Triumph Classifieds 11
RAC68 Top Frame, Hard to Weld Austin Healey 13
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
D Hard Starting Austin Healey 14
aero3113 3000 with clear hard top?? Austin Healey 11
