Tire search
With a UTQG rating of 420 they are very hard and will still have good tread when they are dry-rotted from age. They are designed for long wear rather than handling.
If you can find it, look for something a bit softer (but you may have to shop in Europe for softer 13" tires).
Yes, I agree. Another Spriter suggested Vredestein T-Trac 2 but can't find a UTQC rating. Do have 165/70R13 or 165/65R13 options.
D TR6 Diamond Back tire striping, has anyone used them? Triumph 3
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
Healey Nut Tire Sizes Austin Healey 10
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
G Rear tire scrubbing!!? Spridgets 23
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
M TR5/TR250 Compatible Modern Tire Size Triumph 5
L TR2/3/3A tire manufacturing build date Triumph 2
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J TR6 Tire Recommended for TR6 Triumph 3
S TR2/3/3A tr3 spare tire fit Triumph 16
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
C How to remove entire dash panel on BN6? Austin Healey 4
L General TR tire age code Triumph 3
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
AUSMHLY Wheel Tire Camber Austin Healey 57
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
O TR2/3/3A Spare tire Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
F TR2/3/3A Spare Tire Size Triumph 11
H Tire choices for Bugeyes Spridgets 14
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
M Wanted This entire web site moves like a glacier Austin Healey Classifieds 9
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
Darwin Spitfire Max tire width Triumph 4
