TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3
karls59tr
Bronze
Not sure if this is a dumbass question or not but what was the reason for an "aluminumn" plug in the head? Was this in case the water? froze in the engine block, the plug would be forced up and relieve the pressure, similar to the frost plug in the block? The original plug in the TR3 head was replaced at a rebuild with another aluminumn plug only this one was threaded into the head.(been in there for years with no sign of corrosion.) If they do corrode ,as was mentioned before, would I not be further ahead with a "cast iron" NPT plug to avoid corrosion issues? On the other hand aren't there aluminum compatible antifreezes on the market that would make corrosion a non issue? Randall?
"Freeze" plug is a misnomer. If the coolant does freeze, you will not save your block or head. They will crack. Sorry, don't know why they would choose aluminum for a plug material.
John
Like most "freeze plug" holes, the hole in the head was actually used to help support the cores that form the coolant passages during the casting process. The cores are normally made from sand that is only lightly stuck together (so it can be broken up and removed once the cast iron is cool), so they need to be well supported in order to not break or shift during the casting process. Once the casting is finished, the hole is of no further use, so it gets "permanently" plugged.
https://en.wikipedia.org/wiki/Core_(manufacturing)
BTW, there is no "freeze plug" in the block on TRactor motors, because they are cast without the liners in place and thus there are plenty of places to support the cores. Go look
There are some other plugs of course, but they also have to do with casting or machining processes. There is no attempt to preserve the block during freezing.
You are quite right, the plug should not corrode, IF the antifreeze is always kept up to date. Antifreeze contains various compounds to protect the aluminum.
But, those anti-corrosion additives wear out over time, even if the engine is not driven at all. Most people don't bother changing the coolant when they haven't driven the car, which allows the corrosion to proceed. If you look inside the thermostat housing, you can get some idea of how bad the problem is. On my previous 56, it was literally paper thin in places and had been 'buttered' with some sort of adhesive to try to stop the leaks.
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
tinman58 TR5/TR250 Aluminum oil galley plug Triumph 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
R Proper Aluminum Sump Installation Austin Healey 13
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
