T9 or Datsun 210?
MichiganTed
I have a lead on a T9 out of a XR4Ti and I'm debating the pros and cons of the T9 conversion or the Datsun conversion.
Datsun Pros: No body shell mods, gain a seal on the rear of the engine, conversion kits readily available, correct gear ratios.
T9: Smoother / better shifts, seems to be preferred (from my racing contacts). But
- rear engine seal?
- kits and overall cost?
- body shell mods?
- haven't checked gear ratios yet.
Thoughts?
Gerard
Ted,
Do you know you'll also need to modify the remote shift tower for it to fit in the original location?
I've driven both and I can't say I found the shifting noticeably better or smoother. At least not enough to warrant the considerable difference in expense and modifications for it to fit. I think shift feel depends somewhat on condition.
Are you familiar with my kit?
https://gerardsgarage.com/Garage/Tech/5speedKit.htm
M
MichiganTed
Yup, great kit. I've only heard good things about it (and you!). Love your datsun clutch addition. But as a Ford guy who grew-up in Southeastern Michigan (I work for Ford in engine engineering) I'm somehow drawn to the T9...and I can find T9's, I can't find datsun's.
nomad
Not all T9's have the same input and output shafts, do they? The correct size shafts would be something you should check into.
Seems I remember that from somewhere.
The Datsun stuff is getting hard to find!
Kurt.
The T9 is fine tranny and I sell a fair number of the T9 kits for the MGBs, where it is by far the most well thought out,and engineered kit for the MGB. Ok with that being said, I have the abilty to sell the T9 kits for the Spridgets as well, and several people have called me about them, but the body mods are what turns me off about the T9 in the Spridget, the thought of having to cut the crossmember and and a big part of the tranny tunnel, just would be more mods than I think is needed for the Spridget and I always tell folks to go the Datsun route, which I think is the better engineeried kit for the A sreires Spridget.
AS far as buying a T9 kit less the tranny, I think is sort of risky deal, those trannys were scarse here, when you buy the complete kit you get a guaranteed gearbox, and you're not going to save that much finding a used gearbox, for exxmaple I never sold the T9 kit less the gearbox for my MGB customer, they always opt for the complete kit.
Ted, I think the big question is do you want to peel your 65 apart like a can opener for a 5 speed, because thats what the T9 in the Spridget will cost and you're still going to spend $2000+ to get the rest of the kit, if you find a T9 gearbox. If you still determined on the T9 call me and I get you solid quote on the kit minus the gearbox.You'll find the T9 rare, it only come on Merkurs in the US, but on tons fo cars in Europe, while it is a Borg Warner gearbox, its Eurpoean built BW gearbox, not a US built BW gearbox, so kinda rare here.
G
According to Frontline the US T9 won't work due to a different input shaft. Their kit is designed around a different lenth shaft. I think I have it in my email somewhere.
G
Here:
"If you are getting your own gearbox please be aware of 2 things:
The gear lever position will be approximately 3" further back so you will need to modify your existing tunnel cover & carpet. (This is why we use the "short remote" modification on our gearboxes to avoid this.
The type 9 box we use was fitted to the Sierra in the UK but I have not heard of a vehicle fitted with this box in the USA. The Merkur had a different type 9 box which has a longer 1st motion input shaft and this is not suitable for our kits. I have attached part of a magazine article about these boxes which may help."
Regards
Maggie Patston
Frontline Developments
9 Station Yard
Steventon
Abingdon on Thames
M
MichiganTed
I believe there are three input shaft lengths for the T9. The Merkur XR4Ti in the states used the middle of the three if I'm not mistaken. And I have to agree with Hap 100%. I don't like the idea of cutting up the body shell. Perhaps I'll buy the T9 anyway for trade. Thanks for all the input, you've helped me decide,
Westfield_XI
Is no one going to respond about the whole idea of a seal at the back of an a-series engine? IMHO this is much more controversial than which gearbox.......
M
MichiganTed
A seal for the back of the engine is a big plus from my perspective. Nothing worse than oil leaks and these vintage cars all leak,
nomad
Forget the discussion but I believe some seal kits are better than others. Paul A's method of just closing up the tolerances on the A series worked quite well I believe, along with a working PCV. Should be covered in tech articles somewhere, perhaps someone will chime in. Personally, how do you know its british if it doesn't mark its territory!
Kurt.
Gerard
Kurt.
The Morriservice technique has generally been a successful and cheap solution, however, you will be destroying the main cap and half moon seal in the process. If it doesn't work for you (and is doesn't always work successfully), there's no going back. A new main cap and half moon seal will need to be purchased, and a complete tear down for a trip to the machine shop for a line bore will be the only fix. I have never found it worth the risk. I have had a lot of success with <span style="font-style: italic">my version</span> of the lip seal conversion, as have others.
Westfield_XI
Gerard, what does retrofitting your seal to a Rivergate plate entail? How long does it take to do the work and approx. how much does it cost?
Gerard
Westfield XI,
You've have to machine the plate like mine is in the crank area for it to fit. Installing the seal itself should take you less than an hour. It fits without modification with any other stock gearbox. Contact me off list for other details.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
bugedd Datsun 210 Trans Question Spridgets 9
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
RickB Datsun 210 with manual transmission $500 Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
bugedd Datsun 210 trans question Spridgets 33
RickB Datsun 210 on Craigslist Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 0
RickB Datsun 210 motor and 5 speed Spridgets 6
B How to identify a Datsun 210 5-speed transmission Spridgets 1
B Datsun 210 donor Spridgets 2
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
G Datsun 210 5 speed disassembly Spridgets 23
B Datsun 210 trans value? Spridgets 32
T Shift Levers for Datsun 210 5 speeds???? Spridgets 34
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
RickB Datsun 210 w/5sp Seattle Craigslist [nfi] Spridgets 0
T Datsun 210 - noisy? Spridgets 8
lbc_newbie Datsun 210 tranny....ventilation or missing screw? Spridgets 2
Gundy Looking for a Datsun 210 tranny Spridgets 16
RickB Datsun 210 for sale in WA [craigslist] Spridgets 3
M Datsun 210 Trans Problem Spridgets 9
B Another Datsun 210 w/5-speed in Seattle Spridgets 9
B Datsun 210 w/ 5-speed FS in Seattle Spridgets 0
mrsprite Who needs a Datsun 210 tranny? Spridgets 12
B Datsun 210 w/5-speed near Seattle Spridgets 2
M Datsun 210 Tran/Ebay Spridgets 19
msoylemez datsun 210 trans oil capacity Spridgets 4
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
shadowfever Datsun 5-speed info neede Spridgets 5
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Bayless Started adapting the datsun gearbox today Spridgets 46
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
Marvin Gruber Datsun 2000 Other Cars 12
