Datsun 210 Trans Problem
MCS
Hello,
I started my new rebuilt engine today. I sure hope the second time I have it all correct. This is costing me a fortune in parts. The good news after two hours of running the engine, seems very happy. Not even a single spot of oil on the driveway, sure hope it stays that way. The bad news part is my newly installed datsun 210 trans has a problem. It shifts fine on the way up but when shifting down 2nd gear is difficult to get back into. If I slow to 20 mph I can shift into 2nd. The clutch works perfect. I did a search here and found that maybe my oil is the problem. I switched from 90 synthetic oil to 80w regular gear oil, still same problem. On my bench is the rivergate trans rebuild kit I ordered it at the same time as the kit hoping that if I have it I will not need it. Any ideas before I again remove the engine, at this rate I may pass Jack for most times out of the car.
I have the transmission manual in front of me and trying to determine if I should do it myself, I enjoy the challenge. My only concern is I am running out of engine pull patience.
So two questions.
!. Any ideas on possible problem with 2nd gear down shift, is this a common problem Is this the sync gear causing the problem
2 How many of you have rebuilt this trans using the manual on rivergates site. Are there any other manuals out there?
Cheers Phil
bgbassplyr
MCS>
Don't know any thing about Datsun boxes, but problem is common to any straight drive. First suspect would be the 2nd gear syncro ring. Will it go into 2nd above 20 mph if you double clutch it (heel and toe)? If it will, syncro ring probably the culprit. Or maybe worn thrust washer(s). Or maybe worn shift fork. What are the RPM'S at 25 in 2nd?
Don't know the internals or construction of this box re: thrust washers, so just guessing.
Do you have this problem in any other gear? 2-3, 3-4?
Jim
Westfield_XI
To rebuild the 210 trans follow the detailed instructions & photos in the Haynes Datsun 210 manual. I was looking through one at our local used bookstore the other day and was tempted to buy it for myself. Also I thought the 210 tranny used engine oil, 30 or 40 wt, although I could be wrong.
twas_brillig
Re: Datsun 210 Trans Problem: info on rebuilding
Check the CHRISS web-site, specifically
https://www.spridget-tech.com/Datsun/transmission_book_300dpi.pdf
for rebuilding info. I sent him an anticipatory note of thanks, as I'll be ordering the Rivergate kit and their trans rebuild package, and am glad to have this resource.
Doug
MikeMcKay
Member
For the time period the 210 transmission was built in I would also think the oil would probably be something in the 30 to 40 weight range. Synthetic also causes problem in some manual transmissions.
On my front wheel drive cars (Dodge) from the 80's 10W30 weight is used. Remember the final drive is also in the FWD.
M
MCS
Thanks for the replies.
The oil weight I am certain is 90w, which has been discussed many times.
Not sure of the rpm’s in 2nd gear, will check Sunday afternoon. The trans works great in all gears shifting up, and also works great shifting down in all gears except 2nd. My guess is the syncro for 2nd is the problem. The trans manual link is the same as what rivergate lists. Looks like time to take engine out again, I need a zipper on this thing.
Phil
regularman
I would not run anything thinner than 90 wt unless you like to hear gear whine with the top up. The thicker the quieter. I would suspect a bent fork or maybe a synchronizer. 2nd is the one most people like to jam into when slowing and turning in. Mine has worked fine but let me know how it goes, you never know. Does it not want to go in at all or does it go in and pop back out?
Pythias
Has this tranny been recently rebuilt? As in the last couple of years? There is known issue with the 2nd gear synchro rings. Paul A. of MorrrisService found this out the hard way. They were (are still?) coming from the factory out of spec. If it's been recently done it may have one of these "bad" synchro rings. Paul bought about 100 and checked them all. About 1/2 were no good. Brand new, but no good.
mrsprite
According to my Datsun 210 manual, 90 weight is the recommended oil for the transmission. It's also what I have been running in mine sine I bought it 3 years ago and I've had no issues.
M
MCS
Hello,
Great day for driving I put a 100 miles of mostly short trips on my new motor combo. The motor worked great but the transmission works great if you skip 2nd gear. After 100 miles I had hoped maybe it would start working better,the trans was sitting in the junkyard for years. The 2nd gear still works fine on the up shift so from 1 to 2 there is no problem. It is the downshift from 3 to 2 that grinds until below about 20 mph and 2000rpm. So I swept the garage out tonight and decided Monday will be engine out day. I should setup a timer and see how long it takes.
I have looked through the trans manual a couple of times still not sure if I should do the rebuild myself.
I do not know the history of this trans as I purchased it off a guy in Arizona who purchased it from a guy selling it on eBay in Florida. Hard to believe but this trans went from Florida to Arizona and then to Toronto. I have a full rebuild kit on my bench I bought it from Rivergate and I sure hope it has everything I need. The Rivergate conversion kit was expensive but it works perfect. Very impressive kit and worth the money.
Cheers Phil
bugedd Datsun 210 Trans Question Spridgets 9
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
bugedd Datsun 210 trans question Spridgets 33
B Datsun 210 trans value? Spridgets 32
msoylemez datsun 210 trans oil capacity Spridgets 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
RickB Datsun 210 with manual transmission $500 Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
RickB Datsun 210 on Craigslist Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 0
RickB Datsun 210 motor and 5 speed Spridgets 6
M T9 or Datsun 210? Spridgets 15
B How to identify a Datsun 210 5-speed transmission Spridgets 1
B Datsun 210 donor Spridgets 2
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
G Datsun 210 5 speed disassembly Spridgets 23
T Shift Levers for Datsun 210 5 speeds???? Spridgets 34
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
RickB Datsun 210 w/5sp Seattle Craigslist [nfi] Spridgets 0
T Datsun 210 - noisy? Spridgets 8
lbc_newbie Datsun 210 tranny....ventilation or missing screw? Spridgets 2
Gundy Looking for a Datsun 210 tranny Spridgets 16
RickB Datsun 210 for sale in WA [craigslist] Spridgets 3
B Another Datsun 210 w/5-speed in Seattle Spridgets 9
B Datsun 210 w/ 5-speed FS in Seattle Spridgets 0
mrsprite Who needs a Datsun 210 tranny? Spridgets 12
B Datsun 210 w/5-speed near Seattle Spridgets 2
M Datsun 210 Tran/Ebay Spridgets 19
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
shadowfever Datsun 5-speed info neede Spridgets 5
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Bayless Started adapting the datsun gearbox today Spridgets 46
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
Marvin Gruber Datsun 2000 Other Cars 12
