Stromberg Cold start issues
stradi
I have a 74 tr6 with stromberg carbs. They were rebuilt 2 years ago and have worked great until this year. When it is really cold here in Utah (below 40) and the car sits for a few days it takes for ever to start. Prim the pump. Pull the chock out and crank and crank the engine. One cylinder will start to fire then the others will fallow. Changed out the needle valves, adjusted the floats to about 16mm. Same thing. Then read something about trying to start with starting fluid. Took off the air cleaner and squirted some in each carb. The engine fired right up on the first turn. So I'm guessing I'm not getting fuel when I try to start. I've run out of ideas. Also checked the fuel supply and it is good. After I do get it started it runs like a champ, plenty of power and good fuel economy. Any Ideas?
Michael Scoggins
First place I'd look is at the gaskets under the cold start valves.
That was going to be one of my next adventures, looking at the cold start valves.
In no way is this a comparison of the 2 climates, but down here, I found that I get faster start-ups with a Pertronix ignition.
check to make sure choke and cables are properly adjusted and that choke is fully closed when pulled out.You also can adjust fast idle speed on the choke cam. First pic choke full open,second one fully closed.
Looks like i gotta do a little cleaning in there :blush:
Thanks for the pictures. I will check it out tonight.
So Casey, where did you get those shiny chrome covers for the dash pots? Pretty Cool..........
I agree with Opa, check the cables to see if they fully actuate the choke. Sounds like the cable on one or both carbs slipped a bit.
Victoria British used to sell them and maybe still do....I don't know. They used to sell them for the 175 and 150 ZS.
After making the previously mentioned adjustments, I would adjust everything back to how it was when it was running great.
It is very hard to resist the urge of adjusting things when the carbs aren't working properly. But you have to remember that the engine was running well at the current settings. Carbs go out of adjustment so slowly with wear, that we don't notice the changes.
Common things to look at when Strombergs aren't operating properly would be: ignition, vaccuum, diaphragms, fuel filter, gaskets and o rings, damper oil, and linkages.
Good luck in solving your problem.
But the best advice I can give is, once they are set up, leave them alone.
Thanks to everyone that put up suggestions. It was the photos from Opa that did the trick. One of the chock cables had slipped out of position causing one chock to hardly open. Reset the fast ideal cam and repositioned the chock cables and presto. It started on the second turn of the key. Thanks again. Start with the simple stuff.
Michael Scoggins
bluemiata90 zenith stromberg cold start adjustment Triumph 5
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
