    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Stomberg Needles?
A. Salnick
I am about to rebuild my Stromberg carbs for my TR6. My engine is mostly stock, but I plan to bump the compression ratio up and add a good cam to the setup, and maybe someday a triple Stromberg intake. I was wondering if anybody had any experience with using non-stock needles in the carbs (or even if they exist). I know that in the SU world there are a ton profiles. It seems like the some should exist for the Strombergs. Anybody had experience or recommendations in this arena?
Hello A. Salnick,
there are many more S.U. needles available than Stromberg needles. I can't advise on which needle may work but you can make up a sleeve to use S.U. needles in a Stromberg.
All you now need is what needle?
Alec
There are richer needles available for Strombergs through Burlen Fuel Systems (UK). If you have fixed needles-pre '71 you may want to try B1AR. These should also be available through vintage Jaguar parts suppliers. In the later model TR6's with adjustable needles a B1AQ will give around 20 percent more fuel at wide throttle openings. More info at www.burlen.co.uk.
Mike Crane
I have stock Stomberg needles (B1AF) on my 9.5:1 CR engine with a warmed-over cam and they work fine.
I strongly suggest that you change the needles. I have
high compression pistons, a 2.8cc engine, 3 stombergs.
You may run the risk of having a mixture to lean, this can result in piston damage. If you are interested, let me know, and I will sent you the WEB address where you can find the needles you need.
Regards
Remy
wangdango TR6 TR 6 stomberg/de smogging?? Triumph 4
S Rich Needles - AUD1474 - Guidelines for use? Austin Healey 9
K TR2/3/3A Unmarked SU jet needles? Triumph 3
K TR2/3/3A When to use R [Rich] needles in my SU's? Triumph 14
B s u h4 needles British Motor Corp 5
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
K TR4/4A SU's Again..."RH" needles H6 carbs in a 4A. Triumph 4
Simmo Carburettor Metering Needles Triumph 6
D Needles Triumph 1
D Needles Triumph 5
RickB HIF4 carbs - metering needles? MG 16
Nelson Float needles and seats Spridgets 8
B triple carb needles? Austin Healey 2
T HS2 needles Spridgets 1
M Lean Needles for SU, AUC 878 Triumph 1
R Early ZS Carb Needles Triumph 11
Anthony_S SU H6 - What needles are you running? Triumph 13
B TR2/3/3A TR3 gauge needles Triumph 10
JPSmit New thread - 93 miles tank [Carb needles] Spridgets 0
K TR2/3/3A TR3A SU H6...stock.needles? Triumph 3
K TR2/3/3A TR3 SU Needles in relation to modified cam? Triumph 6
poolboy Fat Needles... a carb adjustment problem Triumph 4
jhorton3 Needles and Seats Spridgets 8
B MGA Carb needles in MGA 1800's MG 2
F Carb Needles Triumph 2
eschneider hs6 "414" needles - 2000 rpm idle Triumph 13
NutmegCT H6 needles Triumph 2
K TR3 SU needles. Racing 5
K TR2/3/3A TR3untapped power from SU needles re Oxygen Sensor Triumph 24
A Air cleaners / carb needles MG 5
K TR2/3/3A TR3 Fast Road Cam and "RL" SU needles Triumph 4
F Carb needles Triumph 3
Atrus HS2 jet needles Spridgets 4
Woodie K&N and needles Spridgets 3
K TR2/3/3A TR3 upgraded cams & richer SU needles?Advice? Triumph 5
Woodie carb needles Spridgets 6
Eleven SU Carb Needles Triumph 0
S TR6 TR6 Stromberg needles Triumph 2
trrdster2000 Pins and needles Triumph 0
R6MGS T-Series MGTC Carb Needles MG 7
I GY versus V3 needles in SU carbs Spridgets 1
M Carb needles, roller rockers. MG 2
Got_All_4 STROMBERG NEEDLES FOR 3 CARB SET UP Triumph 2
W Centering The Needles MG 5
I ZS metering needles Triumph 1
