    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Carburettor Metering Needles
Simmo
Lookig for some advice please.
I have my TR3A now rebuilt with a standard engine except for the Feruson Pistons. I have installed a new set of HS6 Carburettors with TW needles.
Now I have some running problems.
When the engine is idling at around 900RPM it seems just fine. Not rich or lean and it revs up fine too.
Under load it seems very reluctant to rev in the 1200- 2000 RPM range. When it gets going its fine but very hesitant after you have slowed down and foot back on the gas it tends to not want to regain revs.
Im wondering if this is a needle problem or maybe even vacuum advance, which is installed and set as per book.
Any suggestions would be apreciated
Should rev just fine, even without the vacuum advance. Did you have the line disconnected when setting the timing?
1200 rpm is pretty slow to be applying a load, not much power down there. Maybe you just need to drop a gear?
What do you have in the carb dampers?
Have you double-checked the cam timing?
Randall,
Didnt have the line disconected and the bellows etc are working properly.
I mean I do drop down gears but even starting offf in 1St it is rough getting the first few hundred revs going but when I get to say 2000 its just fine.
Cam timing. No what do you suggest.
Singer Sewing Machine oil is in the dampers.( very light 3 in one I think they call it in the US)
Cheers
Ian
Try a heavier oil in the dampers, such as whatever engine oil you're using. If the oil is too light, the piston will fly up too quickly. The oil in the damper slows and smoothes the movement of the piston. On hard acceleration, vacuum that would otherwise quickly lift the piston is redirected to quickly suck more fuel out of the jet. As the piston slowly continues its rise, the mixture returns to a more normal ratio.
You could replace the "3 in 1" damper oil with mineral oil for even more of an accelerator pump effect.
Thanks a million Guys! The change from "3 in 1" to 20-50 engine oil did the trick. I can now accelerate away, in top gear, from 1000RPM without any coughing or spluttering.
The idea seemed far too simple to work but how wrong I was!
Most manufacturers recommend using the same oil you use in the engine. I know there is a lot of opinions, but all thru the years the manuals all said use the engine oil.
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
N Leaking Carburettor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
T Spitfire Carburettor gasket Triumph 1
magman 100M etched carburettor numbers Austin Healey 4
bigjones Drilling carburettor Spridgets 11
Tabcon OER carburettor vs. Weber Triumph 5
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
A carburettor air valve sticking Triumph 3
R Carburettor suction chamber cap loose - why? Austin Healey 23
R Carburettor oil MG 32
J Overheating carburettor Jagf Jaguar 10
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
RickB HIF4 carbs - metering needles? MG 16
I Zenith stromberg metering needle removal help Triumph 9
I ZS metering needles Triumph 1
S Rich Needles - AUD1474 - Guidelines for use? Austin Healey 9
K TR2/3/3A Unmarked SU jet needles? Triumph 3
K TR2/3/3A When to use R [Rich] needles in my SU's? Triumph 14
B s u h4 needles British Motor Corp 5
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
K TR4/4A SU's Again..."RH" needles H6 carbs in a 4A. Triumph 4
D Needles Triumph 1
D Needles Triumph 5
Nelson Float needles and seats Spridgets 8
B triple carb needles? Austin Healey 2
T HS2 needles Spridgets 1
M Lean Needles for SU, AUC 878 Triumph 1
R Early ZS Carb Needles Triumph 11
Anthony_S SU H6 - What needles are you running? Triumph 13
B TR2/3/3A TR3 gauge needles Triumph 10
JPSmit New thread - 93 miles tank [Carb needles] Spridgets 0
K TR2/3/3A TR3A SU H6...stock.needles? Triumph 3
K TR2/3/3A TR3 SU Needles in relation to modified cam? Triumph 6
poolboy Fat Needles... a carb adjustment problem Triumph 4
jhorton3 Needles and Seats Spridgets 8
B MGA Carb needles in MGA 1800's MG 2
F Carb Needles Triumph 2
eschneider hs6 "414" needles - 2000 rpm idle Triumph 13
NutmegCT H6 needles Triumph 2
K TR3 SU needles. Racing 5
K TR2/3/3A TR3untapped power from SU needles re Oxygen Sensor Triumph 24
A Air cleaners / carb needles MG 5
K TR2/3/3A TR3 Fast Road Cam and "RL" SU needles Triumph 4
F Carb needles Triumph 3
Atrus HS2 jet needles Spridgets 4
Woodie K&N and needles Spridgets 3
K TR2/3/3A TR3 upgraded cams & richer SU needles?Advice? Triumph 5
