TR4/4A Carburettor is French for DON'T TOUCH!
rnpennington
OK, I didn't follow the directions in the title and I touched them. Didn't drive the car for a while and the floats got stuck and fuel was pouring out the bottom of the carbs, ZS 175CD carbs. OK, easy fix I think, took the carbs off, opened the bottom to reset the float, changed the o-rings in the jet assembly. However, it took about three weeks for this all to happen.
Now, having taken them apart I know I have messed up the settings from before. How to I get it to a setting that will run the car and allow me to adjust it properly? At this point, it will not run, only start with starting fluid.
First question, what I have marked as Part 1. Is this screwed in all the way to the top or some other position?
Second, once part one is fixed properly, do I screw part 2 in all the qway and back off a certain number of turns or what?
Thanks for the help!
poolboy
Screw the big one all the way until it is tight, but not king kong tight. Make sure you have a GOOD O-ring in that groove.
The small one is the actual jet adjustment 'screw'
The best way to set the jet is to remove the top of the carb, the spring, then the air valve with the 'rubber' diaphragm attached so you can see (and measure) the jet... then using the adjustment screw turn it until the HOLE in the jet is about 1/10 of an inch below the surface of the bridge...that's the baseline setting.
I hope I'm safe in assuming you know how the air valve and diaphragm fit back in their proper place
In the future for fine tuning when viewed from ABOVE Counterclockwise rotation of the adjustment screw raises the jet, which leans the mixture
Sarastro
There's plenty of information on-line and in the shop manual about adjusting carburetors. Also, in the archives here. I think you should start by educating yourself on the way Strombergs operate--much the same as SUs, and probably there is more info on them, so any info on SU info you find is mostly relevant, too. They're actually pretty simple.
The only tricky adjustment, in my experience, is the mixture. I find it easier on SUs, as the effect of lifting the damper is more pronounced. But, with a little care and experimentation, you should get good results.
N Leaking Carburettor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
T Spitfire Carburettor gasket Triumph 1
magman 100M etched carburettor numbers Austin Healey 4
Simmo Carburettor Metering Needles Triumph 6
bigjones Drilling carburettor Spridgets 11
Tabcon OER carburettor vs. Weber Triumph 5
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
A carburettor air valve sticking Triumph 3
R Carburettor suction chamber cap loose - why? Austin Healey 23
R Carburettor oil MG 32
J Overheating carburettor Jagf Jaguar 10
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
Sherlock A report from hinterland (and French cars) Spotted 4
rick_ingram General MG IMPORTANT - If you attended MG2014 in French Lick, PLEASE read this! MG 1
JLTinkham MGC French Lick MG 2
NutmegCT Old French cars anyone? Other Cars 2
aeronca65t French SPridget Owners Club Spridgets 3
Sherlock A little Japanese, British & French Spotted 7
John_Mc TR6 French Blue TR6 sighting at Lake Tahoe Triumph 1
jjbunn French Horn Triumph 10
jackq French fry power... Other Cars 2
V French 3 cylinder car racing in the late '70's Racing 3
T MGB Quick question about something that don't really matter just want to know. MG 9
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
jlaird MGB Don't post like I did 10 years ago. MG 7
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
PC somethin' I don't see evrey day Spotted 1
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
CJD General TR Parts Just Don't Last Anymore Triumph 6
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
Gliderman8 Lights don't break FORUM Navigation Questions 23
S TR2/3/3A Don't throw anything away. Triumph 7
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
JPSmit I don't always dream of owning an RV Other Cars 0
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
Geo Hahn General TR R.I.P. Don Elliott Triumph 13
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
D TR6 Rear lights don't work. Grounding Problem ? Triumph 14
1 MGB I don't know how or why, but I think I will need a new clutch :[ MG 4
Csarneson Old Engine - Journals don't fit? Austin Healey 2
N Things you see when you don't expect it. Spotted 1
HealeyRick You Don't Need a Weatherman ... Austin Healey 9
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
vette Vapor Lock, Out of Gas, Hmm, Ahh, Don't know? Austin Healey 32
Mickey Richaud MGB Don Hayter Gets His Watch MG 1
PC don't know, but I have a pretty good idea, Spotted 0
Lukens Don't hate me... Austin Healey 22
