TR2/3/3A Don't throw anything away.
STeve 1958
Last night I went through all my wiring and got everything to work except the windshield wipers which are always on. Short to ground I assume.
After trying for an hour to get the left rear turn signal to work I finally checked the bulb. Doh! It was burned out, so I dug through some old stuff and found a box of light bulbs that I purchased in 1974. If I can find the wiper short I'll finally have everything operational.
Steve
The wiper wiring shown in many diagrams is wrong for all but the earliest TR3s. If you have the wiper motor on the left, then the switch is supposed to ground terminal 1 to make the motor run continuously.
Find out which wire on the motor is hot, then disconnect the other one (which should be terminal 1). If it still runs, the problem is inside the motor. If not, problem is wiring to the switch. Possibly one of the under-dash modifications accidentally used the wire from the wiper motor as a power source.
Inside (well, mostly inside anyway) the motor, there is a wire that runs from terminal 1 over to the park switch on top of the wiper gearbox. (The park function works by grounding that terminal through a switch mounted on the gearbox.) On most motors, that wire runs through a hole in the motor housing and connects to the park switch on the outside. It may be grounded where it goes through the hole (which would make it run all the time). Or the park switch itself may be damaged, especially if you have the other style of motor.
Thanks Randall, I hadn't though of an internal short, that's tomorrow night job. Of course what do I need with windshield wipers since I don't yet have a rag top.
Steve
As long as you drive fast enough, the rain flies over your head. But you still kind of need to see where you are going!
I don't have a top either (it never rains in southern California), but there have been more than a few times I wished the wipers worked.
One time, I thought sure I was going to get a ticket for no wipers, but the cop just yelled I should get some Rain-X and drove on :smile:
That finally motivated me to install the motor and so on.
FWIW, I like the flexible wiper blades from an MGA much better than the rigid ones Triumph used. The MG blades follow the curve of the glass better, and are a direct replacement for the Triumph ones. Sorry I don't have a P/N handy, but you can find it on the Moss website.
I switched to the MGA wiper blades and they are much better than the original TR ones. They actually wipe off the windscreen. Moss part # 164-980.
Ya It never rains in Northern Ca. either. Problem is I'm moving to Florida next year.
I'll definitely need some new wiper blades if I ever get them working.
We moved from the Bay Area to Idaho. I had to get the wiper motor for the 250. Not so much for the rain but for the over spray of water from the farming fields.
T MGB Quick question about something that don't really matter just want to know. MG 9
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
jlaird MGB Don't post like I did 10 years ago. MG 7
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
PC somethin' I don't see evrey day Spotted 1
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
CJD General TR Parts Just Don't Last Anymore Triumph 6
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
Gliderman8 Lights don't break FORUM Navigation Questions 23
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
JPSmit I don't always dream of owning an RV Other Cars 0
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
Geo Hahn General TR R.I.P. Don Elliott Triumph 13
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
D TR6 Rear lights don't work. Grounding Problem ? Triumph 14
1 MGB I don't know how or why, but I think I will need a new clutch :[ MG 4
Csarneson Old Engine - Journals don't fit? Austin Healey 2
N Things you see when you don't expect it. Spotted 1
HealeyRick You Don't Need a Weatherman ... Austin Healey 9
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
vette Vapor Lock, Out of Gas, Hmm, Ahh, Don't know? Austin Healey 32
Mickey Richaud MGB Don Hayter Gets His Watch MG 1
PC don't know, but I have a pretty good idea, Spotted 0
Lukens Don't hate me... Austin Healey 22
M I don't love her anymore Spridgets 5
D Don't buy top plate shims for bishop cam steering from Moss Restoration & Tools 5
bugedd Don't know what to do Spridgets 17
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
C Order of Assembly? Do and don'ts? Austin Healey 9
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
Bob_Spidell Why I don't drive my Healey to Mexico [any more] Austin Healey 4
longbridgehealey Another I just don't understand electricity question Spridgets 6
D Don't ignore stiff window regulator Austin Healey 8
A Big Healey Restoration Do's & Don'ts Austin Healey 11
B settings don't stick FORUM Navigation Questions 0
D Information about Don Wylie Racing 0
X don't fix it if it ain't broke Spridgets 1
J Weld thru Primer, I don't like it! Restoration & Tools 2
J why they say don't buy replacement fenders! Triumph 4
cmacmillan straw poll - snaps don't line up Triumph 2
B Don't laugh..!! MG 8
Cottontop Don't we WISH it was this easy Restoration & Tools 5
B Second picture. I don't quite get this yet Triumph 1
T Stag Don't let the Triumph Stag lose! Please! Triumph 11
rkep01 Chrome? We don't need no stinkin' chrome! Spridgets 10
rkep01 On the subject of new parts that don't fit... Spridgets 38
J Propshaft spins but wheels don't Spridgets 22
