Squealing brakes
mgperson1
I recently put new disk pads on my MGB and they squeal terribly. I took them off and glued the pads to the pistons with "squeal stop" but it is actually worse.
Any ideas??
Administrator
Boss
Are the pads "metalized?" If so, you might try buying a different type of non-metal pad. Also, I don't know about the MG, but many cars with disk braks have "squeel reducers" (little metal springy strips that sit behind the pads). If you car has them, make sure they are in place and in good shape. If all that fails, have your rotors checked/turned as necessary. If you have "hot spots" in your rotors, that can cause problems as well. Good luck and let us know how it goes.
By the way, I'm moving this message to the "MG forum" as "Car Care" is really more for discussions of cleaning, detailing, polishing, etc. Ho, and welcome to the forum!
Post moved to "MG Forum"
D TR5/TR250 Squealing brakes Triumph 4
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
Nelson Squealing brakes Spridgets 7
drooartz Squealing brakes at startup in cold weather Other Cars 2
W Bugeye With Squealing Drum Brake Spridgets 5
P MGB MGB overheating with a squealing noise from the engine MG 11
BoneIdle Odd squealing in 4th gear MG 2
SCguy Squealing Belts Triumph 4
sparkydave Squealing brake Spridgets 16
Dave Russell engine squealing MG 12
Hawk813 TR6 TR6 Brakes Triumph 2
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
I MGB Sticky Rotors/Brakes MG 5
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R Bugeye drum brakes Spridgets 7
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Brakes Not Releasing Austin Healey 9
prb51 100-6 Drum Brakes Austin Healey 9
bighealeysource Drum Brakes Assembly Austin Healey 6
A Drum Brakes Again Austin Healey 18
NutmegCT Morris Minor brakes! Other British Cars 9
BritBite XKE BRAKES Jaguar 1
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
algot1901 Brakes for Anglia / Prefect Other British Cars 2
M TR6 76 TR6 Brakes too tight Triumph 10
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
K TR2/3/3A Sticking front brakes? Triumph 9
B MGA After-market brakes MG 5
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
C TR2/3/3A bleeding brakes Triumph 11
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
A TR6 '74 TR6 no brakes Triumph 14
FlyingCat Spitfire Bleedin' Brakes Triumph 6
R TR2/3/3A Rear Brakes Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
HalLucy Post-War Other 1949 2000 Triumph Roadster brakes Triumph 17
S TR2/3/3A Now the bad news. BRAKES Triumph 7
M TR6 Rear brakes Triumph 2
John_Mc TR6 Front brakes won't release Triumph 20
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
P Brakes lock up when rolling forward Austin Healey 4
P Honda weak brakes Other Cars 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
R General Tech Loss of brakes Triumph 11
R 100 Brakes Austin Healey 3
