Sprite 58 turn indicator problems
sim
Installing a new electronic flasher made by CEC Ef33 has 3 prongs . I can get it to work but when the ignition switch is turned on , the dash light flashes when the switch is in the off position. Flick switch to right and right lights blink and dash light still blinking. The same when switch is to left . Left lights blink and dash light blinks. Put switch in center position dash light still blinking but turn lights are off. I pulled the switch and messed with different wire placement. now I was lost so i pulled all wires off to find the hot one. When ignition switch was turned on the dash turn light still blinked. I pulled the green wire off the flasher unit , put the wires back on the switch, turned on the ignition switch and the flasher unit still worked. Just no dash light. So here is my thought. Cut the green wire at the dash light and then add a new wire to the flasher unit . it would connect to the L and R legs. So when the turn lights blink so will the dash light. Think this will work? As the only time the F unit gets power is when the dash switch is switched L or R when ignition switch is on.
dklawson
I am not familiar with how Bugeye differs from other LBCs nor am I familiar with the specific flasher you selected. However....
Take a look at the schematic for the EF33 linked below. Look at the function of the P, X, and L terminals and make sure they match functionally your Bugeye wiring diagram (X = inplug power, L = Load (lamps), P = dash indicator lamp).
https://ceclighting.com/pdfs/EF33.pdf
Again, I don't know how the Bugeye wiring compares to other LBCs of the period. The picture below is how the wire color codes compare to the Triden EL13 flasher on my Mini.
https://sites.google.com/site/purlawson/home/pictures/AftermarketFlasher.jpg
SaxMan
Are you using LED lights? I had a similar problem when I did an LED conversion on my '69 Sprite. Ultimately, I had to swap the LEDs with a different set, which stopped the flashing. According to the supplier, Joe Parlanti at Velocity Solutions, the LEDs were causing "interference" with the other lighting in the vehicle. I wish I understood the interference concept better. Automotive electrics are still a bit vague for me.
Do the dash lights still blink when you turn on the driving lights? Does your tag light also blink? If the tag lights blink, too, then you have some kind of interference issue with your wiring. You may want to swap bulbs and see if that changes anything.
Bayless
The green wire is the hot wire. with it removed from the flasher, the flasher should not work at all. If it does then something is surely amiss somewhere. If you connect both the left and right legs to the dash light then you will have created a "hazzard lights" system. Making either one will also make the other so that all lights flash. I'm afraid you will have to find what is actually wrong. From what I read, I would start with another flasher. It sounds like there may be an internal short between X and P in the one you have. Also heed Doug's advice to ensure you have all the wires connected to the right posts. According to my BE wiring diagram, the green wire goes to the X (or B) post on the flasher, the light green wire connects the P post to the dash light and the L post is connected to the turn switch by a green/brown wire. The green wire should be hot when the ignition switch is on. Hope this helps.
sim
sim
this car is + ground. If I take the hot lead and put it on X nothing happens. However it works on L. Using a test light on X the test light works. From the schematic it looks like one wire from the load to dash light will make the dash light flash in L Or R turns. As the indicator switch has separate contacts which should keep energy to dash light separate.
Still cannot figure out how dash light gets energy when ignition switch is on.
Thanks for your help Sim
sim
sim
Not using LED Will check if other lights blink but I do not think so Do you have a phone number for Joe?
May have to call Joe
thanks
rod
dklawson
Bayless
:iagree: A solid state unit driven by + ground then all bets are off. Without knowing exactly what's inside, it's near impossible to guess why it acts strange, but not surprising.
sim
sim
However It will work with power on L and X the load. I think I can get the the dash light to blink by running a wire from X post to dash light . A test light blinked but I did not try 2 at a time. One test light on each post. Will give that a try later
Thanks
Rod
dklawson
That may work. The indicator light should function as another signal lamp wired as you describe.
nomad
You could also change the system polarity. Pretty simple.
Kurt.
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
Tullamore Dash turn indicator. Sprite MK III Midget MK II Spridgets 1
sim 58 sprite turn signal Problem Spridgets 6
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
HAN8L1965 Turn Signal Question-65 Sprite Spridgets 3
M Front Park Turn Lamps 66 Sprite Spridgets 7
saabmp3 Helping a sprite turn into a 3 month DD Spridgets 31
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
