sim
Let me see if I get this correct. Power to the switch on dash is supplied via ignition switch when key is turned to on.
Problem is I have no power to the turn switch. I removed switch and tested it. only side has 12 volts. The other side has about 1 volt. The ignition switch is about 2 years old. Could a bad turn switch cause the ignition switch to go bad?
thanks
sim
Up date. I do have voltage from ignition switch to one lead of toggle switch. Problem is it is only 6 v
I guess I should check chassis ground points/
thanks
sim
