MGB-GT Sorting my new 1970 MGB GT
Dontyler
I just purchased my GT. It is a one owner California car that we imported to Toronto Canada. Joined the Toronto MG Club as well. Previously have had healeys and a supercharged TD, but never a B.
The car has the Moss Minuki carb setup And pcv kit. I am not familiar with them and am looking for any advice on a stutter at about 3000 rpm That only occurs under full throttle. Stutters, feels like it will stall, clears its throat and pops, then settles back down. feels like a vacuum leak and am starting to trace that down. The pcv is leaking oil around the hose connections, suggesting a leak there at least.
All ideas welcome.
Administrator
Boss
Don, welcome to BCF! You posted your question in our forum that we set up to discuss this new forum software. For this type of specific MG-related topic, you want to post in our "MG" forum. I am moving this thread to the MG forum so if you are reading this now then you are in the MG forum.
Dontyler
Dontyler
Thanks!
JPSmit
welcome neighbour - can't help but you are in the right place. I am in Etobicoke - you?
Dontyler
Dontyler
Small world. Grew up in Humber Valley Village. Currently on Lynwood Ave, 1 block south of St Clair west off avenue road.
Dontyler
Dontyler
Progress, put a clamp on the pcv hose and problem mostly solved. Probably found the main vacuum leak. Idles lower and smooth. a few test miles needed to be sure.
Dontyler
Dontyler
Problem 1 solved with the stutter at 3000 rpm. seems it was a vacuum leak (mostly)
New issue. The car has a T9 5 speed installed by a previous owner. it developed a large leak in the seal around the fifth gear sandwich.
The good news is that with a hoist we were able to remove the transmission without pulling the engine. Off to the transmission shop for new seals and back in service today.
Dontyler
Dontyler
Transmission back in and dry underneath! The stutter is completely gone after the vacuum leak fix on the PCs line and half a tank of new non ethanol gas. I think the car had water in the gas having sat for a long while before I bought it. So far so good, loving putting a few miles on it.
Dontyler
Dontyler
Found a vibration at highway speed and am going to try dynabeads to solve the balance issue as I can not find a local shop who can balance wire wheels. Will report on if the dynabeads make any difference.
Anyone out there with experience using dynabeads?
Bob Claffie
Very recent discussion on Bead balancing on a corvette forum I belong to. General consensus put Bead balancing right up there with snake oil.
Dontyler
Dontyler
After a 3 hour highway drive and a fresh tank of gas the car is running very well. Checked points condenser, rotor and timing and replaced the moving bits, keeping the old usable ones as a backup.
After adjusting the idle and a few highway miles on fresh gas the car feels right.
Kind of proves that a number of small issues can combine, solving the vacuum leak, probably water in the gas and carb adjustment did the trick.
Bottom line is we need to drive our lbc’s much more!
PatGalvin TR2/3/3A Sorting Out "Afro's" TR3 Triumph 10
T MGC Sorting out MGC front calipers MG 1
HAN8L1965 Sorting Her Out to Hit the Road Spridgets 4
mctriumph TR2/3/3A Back to 1970 Triumph 4
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
T For Sale 1970 TR6 project car Triumph Classifieds 0
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
P TR6 1970 TR6 Timing Question Triumph 2
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
AngliaGT For Sale 1970 mgb gt MG Classifieds 4
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
bcliff For Sale 1970 MGB Roadster and other British cars for sale MG Classifieds 0
AngliaGT 1970 Volvo 142 Other Cars 8
TomMull US car assembly standards in the 1970's Other Cars 13
sd80mac7204 Spitfire 1970 Brake question Triumph 3
sim 1970 H2 carb question Spridgets 2
S 1970 Mercedes 280 SL Other Cars 4
Simmo MGB 1970 MGB Speedometer Faceplate MG 5
smaceng TR6 Information Needed on 1970 TR6 Commission Number / Plate Triumph 6
F TR6 Just about finished- 1970 TR6 Triumph 17
JodyFKerr MGB 1970 MGB restoration MG 1
JodyFKerr MGB Tanith's 1970 MGB MG 15
Sherlock 1970/73 Vauxhall Firenza [Canadian version] Spotted 6
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
rovernut 1970 series 2 e type serial number location Jaguar 6
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
B 1970 XKE 4.2 rear main seal Jaguar 2
M Spitfire 1970 Spitfire Dash Triumph 11
S 1970 MG Midget Gearbox Spridgets 2
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
S 1970 MG Midget MG 5
V Locking gas cap for 1970+ Midget??? Spridgets 14
jollyroger GT6 1970 GT6 seat kits and foam Triumph 9
S RUST INSIDE DOORS ON 1970 E-TYPE OTS Jaguar 2
R GT6 1970's Triumph GT6 Craigslist Triumph 4
K MGB 1970 MGB w Mazda Rotary done right! MG 13
RickB MGB-GT Selling my 1970 MGBGT MG 8
A HELP with my 1970 3500 Rover / Land Rover 1
M MGB 1970 MGB roadster wiring harness question MG 0
D retro-fit 1970 etype with three carb set-up Jaguar 3
T 1970's shag carpet Triumph 11
