Spitfire 1970 Spitfire Dash
MikeMcD
Just bought my first Triumph. It's a 1970 Spitfire and I know nothing to very little about it so I'll have all kind of questions. To start with, what are all the dash controls? My electrical is not 100% so several things are not working. Is there a schematic I can download somewhere on the dash controls or wiring in general?
sabot
just try typing , Triumph spitfire wiring diagrams, into google and a few sites will pop up. if you can't find a good one let me know i can send one if no one else does. and welcome to the forum.
tom
Andrew Mace
Try this wiring diagram from triumphspitfire.com. It's technically for the MkIV, but it should be at least 99% the same as your 1970. Meanwhile, for the components that seem not to be working, first point of "attack" is probably the fuse box, where simply wiggling the fuses around might be enough to scuff off the film/corrosion and make good contact again.
TR3driver
Great Pumpkin - R.I.P
Just a thought, might be worth picking up a copy of the owner's manual for your car. It has both a wiring diagram (although the diagram is for RHS cars) and a description of all the controls. Also a detailed maintenance schedule that is worth following.
Used ones show up occasionally on ebay, or I see TRF has new reprints available:
https://www.zeni.net/trf/spitfireGB/170.php
Here are some scans from my somewhat degraded original:
https://i258.photobucket.com/albums/hh260/TR3driver/SpitMk3wiringRHS.jpg
https://i258.photobucket.com/albums/hh260/TR3driver/SpitMk3wiringRHSkey.jpg
M
MikeMcD
Thanks for the diagrams. They will help when I get into the wiring. I do plan on getting a manual, is the Haynes book any good? Unfortunately I'm so new to this I don't even know what all the knobs and levers on the dash a supposed to do. Any chance there is a picture or diagram of a dash with everything labeled?
Andrew Mace
Randall, the problem I see with those diagrams is that they don't seem to include features I suspect are present on Mike's car, which I'll assume is a "Federal" 1970 Mk3. The dashes are different in layout, and the "Federal" cars would have the brake failure warning light, hazard flasher circuit, etc. that the home market cars didn't have. As for the Owners Manual reprints, I honestly don't know if the reprint TRF offers is for the "Federal" cars or the home market cars. If it's the latter, the same lack of information will be present there. That's why I suggest the MkIV diagram above, as it appears at quick glance to be rather closer to what Mike likely has.
Some of the Bentley Manual reprints included both the Owners Handbook and Workshop Manual. I don't have mine handy at the moment, and I can't recall if it included a US version of the Owners Manual.
sabot
Hi guys, if i can figure out how to email the pictures and diagrams from the
heritage Dvd, i will send them tonight, but should i do that on this link, or as a private message?
tom
TR3driver
AFAIK, Haynes only publishes a workshop manual, which probably won't have much of the information found in the owner's manual. For example, your photo of the dash is in the owner's manual, but likely not in the Haynes. But I don't actually have a Spitfire Haynes, so I could be mistaken.
In general, I prefer the factory manuals over the Haynes, but it is just a matter of preference. The Haynes tends to have more diagrams and details for basic procedures, but gloss over some of the more complicated ones; while the factory workshop manual has everything that a professional mechanic needs to know about the car. I'd also say that, in general, the Haynes has more mistakes than the factory manual (but again I don't have the Spitfire Haynes so it might be better than the others).
TR3driver
Did the Mk3 even have a "Federal" version of the owner's manual? I believe that the one I have was originally delivered with a 1968 Federal Mk3; but the wiring diagram does lack the features you mention, and the PDWA warning lamp is shown only in the "Emissions" supplement (which specifies "For North American-type markets only).
PS, my (Brooklands reprint) of the "combo" (Herald/Vitesse/Spit 1,2,3) workshop manual does show the wiring to the PDWA as an inset, but also fails to show a hazard flasher.
Perhaps the hazard flasher was only on 1970 models?
TR3driver
tom
Unless you are a paying member, BCF severely limits what you can post directly. One way around that is to post photos on photobucket.com, then give a link here (as I did above).
Andrew Mace
I'm pretty sure that my 1969 Mk3 came with a "US" Owners Manual showing the "Federal" dash and most, if not all, the wiring changes to include Hazard flashers, etc.
The hazard flashers were on at least as early as 1969; I don't recall when the Federal government standards first mandated them on imports. They were required as early as 1966 on cars sold in New York State, though, and those were definitely added-on kits. And, oddly enough, the factory Herald/Spitfire/Vitesse 6 manual was very spotty on what it did cover in terms of US-spec. models. That manual never had a proper wiring diagram for US Heralds, but I think some of the latest versions did cover at least some of the "Federal" Spitfire Mk3 stuff.
I understand the Herald omissions in the Workshop Manual, since Triumph didn't sell at that many here. They did do a US-specific Owners Manual for the first Heralds, but not for either the Herald 1200 or Sports 6; more importantly, they always did Owners Manuals for US Spitfires from the very start, but that probably had a lot to do with the fact that a very large portion of Spitfire production was sold in the US.
Mark Jones
Hi Mike,
The North American Spec 70 Spitfire is an odd duck. It is almost a 69 with a 70 dash.
Here's the UK owner's handbook: https://www.totallytriumph.net/spitfire/handbook_mk3.pdf
I do have an electronic copy of the N.A. Mk3 handbook.
The dash layout is different but the electrical diagram is similar.
The switch in the middle part of the dash with two gauges on either side is for the lights. The switch above the steering column is the hazard light switch. There may be another one but I haven't been in my Mk 3 very many times (recent acquisition).
mctriumph TR2/3/3A Back to 1970 Triumph 4
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
T For Sale 1970 TR6 project car Triumph Classifieds 0
Dontyler MGB-GT Sorting my new 1970 MGB GT MG 12
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
P TR6 1970 TR6 Timing Question Triumph 2
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
AngliaGT For Sale 1970 mgb gt MG Classifieds 4
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
bcliff For Sale 1970 MGB Roadster and other British cars for sale MG Classifieds 0
AngliaGT 1970 Volvo 142 Other Cars 8
TomMull US car assembly standards in the 1970's Other Cars 13
sd80mac7204 Spitfire 1970 Brake question Triumph 3
sim 1970 H2 carb question Spridgets 2
S 1970 Mercedes 280 SL Other Cars 4
Simmo MGB 1970 MGB Speedometer Faceplate MG 5
smaceng TR6 Information Needed on 1970 TR6 Commission Number / Plate Triumph 6
F TR6 Just about finished- 1970 TR6 Triumph 17
JodyFKerr MGB 1970 MGB restoration MG 1
JodyFKerr MGB Tanith's 1970 MGB MG 15
Sherlock 1970/73 Vauxhall Firenza [Canadian version] Spotted 6
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
rovernut 1970 series 2 e type serial number location Jaguar 6
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
B 1970 XKE 4.2 rear main seal Jaguar 2
S 1970 MG Midget Gearbox Spridgets 2
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
S 1970 MG Midget MG 5
V Locking gas cap for 1970+ Midget??? Spridgets 14
jollyroger GT6 1970 GT6 seat kits and foam Triumph 9
S RUST INSIDE DOORS ON 1970 E-TYPE OTS Jaguar 2
R GT6 1970's Triumph GT6 Craigslist Triumph 4
K MGB 1970 MGB w Mazda Rotary done right! MG 13
RickB MGB-GT Selling my 1970 MGBGT MG 8
A HELP with my 1970 3500 Rover / Land Rover 1
M MGB 1970 MGB roadster wiring harness question MG 0
D retro-fit 1970 etype with three carb set-up Jaguar 3
T 1970's shag carpet Triumph 11
J TR6 Value of 1970 TR 6 project. Triumph 3
RickB NOS right side 1970 bumper on Ebay MG 1
V 1970 XKE for sale Jaguar 0
19_again will 1970 tranny fit in my 66?oun MG 11
