1970 MG Midget
svarelat
Hi: I just bought a 1970 Mg Midget and I'm restoring it. I'm missing the tachometer and the switch located at the tachometer's left. Do you know what the tachometer part number is and which one is the switch located there? Maybe fog lights? Also, do you know where I can find them both (tach and switch)? The other question is: Is this car (1275 cc) a 3 or 4 speed car plus reverse? Thanks alot for you help!
bgbassplyr
Welcome to the BCF forum, where you will find answers to all (or most) of your questions. You will get a faster reply to your question by posting in the Spridget forum. Not all of the Spriget guys (and gals) check the MG forum which is more for the T series, A, B, and C models.
The Spriget forum is very active and a font of information for all things Sprite and Midget.
Again, welcome. We're glad to have you.
davester
I'm pretty sure the switch is the heater fan.
You should be able to find the switch at Moss Motors or (probably cheaper at) several of the forum sponsors, though I'm unsure as to whether you'll be able to find a tach new. Probably need to ask on the spridget forum regarding used ones.
drooartz
Not sure about the switch, but all Spridgets (any year) had a 4 speed + reverse. Your 1970 will be a standard H pattern with first up and to the left in the H.
Reverse is all the way to the right and down.
Welcome!
dklawson
Since you do not have a tach, be flexible. Your 1970 probably came with an 80mm RVI type Smiths tach. That type of tach will not work with electronic ignitions. You can instead fit a later RVC type tach that will look similar and will work with electronic ignitions. Though this may not sound important now, at some point you are likely to want to try one of the aftermarket electronic ignitions and having the RVC tach eliminates one thing to worry about.
S
svarelat
Thanks alot to everyone. I'll be asking for these parts in the forum sponsors and in the Spridget forum, since I also need all the gear pinions! Thanks alot again!
S 1970 MG Midget Gearbox Spridgets 2
V Locking gas cap for 1970+ Midget??? Spridgets 14
Woodie 1970 midget starter not engaging flywhee Spridgets 13
Woodie 1970 Midget - new member Spridgets 23
mctriumph TR2/3/3A Back to 1970 Triumph 4
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 3
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
T For Sale 1970 TR6 project car Triumph Classifieds 0
Dontyler MGB-GT Sorting my new 1970 MGB GT MG 12
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
P TR6 1970 TR6 Timing Question Triumph 2
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
AngliaGT For Sale 1970 mgb gt MG Classifieds 4
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
bcliff For Sale 1970 MGB Roadster and other British cars for sale MG Classifieds 0
AngliaGT 1970 Volvo 142 Other Cars 8
TomMull US car assembly standards in the 1970's Other Cars 13
sd80mac7204 Spitfire 1970 Brake question Triumph 3
sim 1970 H2 carb question Spridgets 2
S 1970 Mercedes 280 SL Other Cars 4
Simmo MGB 1970 MGB Speedometer Faceplate MG 5
smaceng TR6 Information Needed on 1970 TR6 Commission Number / Plate Triumph 6
F TR6 Just about finished- 1970 TR6 Triumph 17
JodyFKerr MGB 1970 MGB restoration MG 1
JodyFKerr MGB Tanith's 1970 MGB MG 15
Sherlock 1970/73 Vauxhall Firenza [Canadian version] Spotted 6
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
rovernut 1970 series 2 e type serial number location Jaguar 6
S XKE 1970 Series II OTS Outside Mirror Jaguar 3
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
B 1970 XKE 4.2 rear main seal Jaguar 2
M Spitfire 1970 Spitfire Dash Triumph 11
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
jollyroger GT6 1970 GT6 seat kits and foam Triumph 9
S RUST INSIDE DOORS ON 1970 E-TYPE OTS Jaguar 2
R GT6 1970's Triumph GT6 Craigslist Triumph 4
K MGB 1970 MGB w Mazda Rotary done right! MG 13
RickB MGB-GT Selling my 1970 MGBGT MG 8
A HELP with my 1970 3500 Rover / Land Rover 1
M MGB 1970 MGB roadster wiring harness question MG 0
D retro-fit 1970 etype with three carb set-up Jaguar 3
T 1970's shag carpet Triumph 11
J TR6 Value of 1970 TR 6 project. Triumph 3
RickB NOS right side 1970 bumper on Ebay MG 1
