Small Puff of Black Smoke When I Blip Throttle
Martinld123
Bronze
If it isn't one thing it is another, lol. My latest concern is when I blip the throttle from idle on my 100 BN2 there is a small puff of black smoke coming from the exhaust. This was not there until recently on my freshly rebuild engine with 3300 miles on it. It clears if I blip the throttle a few times but returns if car idles for just 10 seconds or so. No smoke at idle that I can see. All four plugs are gray to coffee color with just a small ring of carbon on outside thread edges. Can only be seen if standing at back of car and just started I believe? Thanks Marty
Keoke
If the smoke is not white, you are alright-:greedy_dollars:---Rich carbies
bdcvg
unless You are experiencing excessive oil usage , I would not worry much. Maybe somebody else will have a more educated cause.
Here's my theory: Engine is 'loading up' at idle; i.e. with no load some unburned fuel remains in the cylinders. When you rev the engine--esp. if you start to move--the 'mean effective pressure' increases and the leftover gas gets burned resulting in a momentarily rich mixture; hence a puff of black smoke.
Martinld123
Martinld123
Bronze
John,
Yes I used straight 30W oil for sometime when I thought I was running lean on acceleration. I know it should be 20W and changed it back yesterday. I have turned jet mixture in 1 turn to see if that makes difference also. Plugs seem good though. Marty
vette
Marty, a little black smoke at idle just means the carbs are alittle rich. If it is running well and idles well then it is nothing to worry about. If you want to try to get rid of it then you can adjust the carbs alittle leaner which it sounds that you have done that. But I don't adjust any SUs unless I have done the mixture test as described in the book. Dave.
P A small group outing. Spotted 2
H For Sale 1956 Small Mouth TR3 Kit Triumph Classifieds 0
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
S TR2/3/3A lower small brass bushing Triumph 13
JPSmit Small gathering of club members today Spotted 6
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
7 General TR Small parts Triumph 2
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
D TR2/3/3A More small nuts [ and studs!] Triumph 2
nevets Small Healey-related tidbit Austin Healey 2
S Rear axle - small leak .....? Austin Healey 7
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
R For Sale 1956 Early small mouth TR3 Triumph Classifieds 1
Michael Oritt Small world Austin Healey 15
M TR2/3/3A Late 57 Production with a Small Mouth Apron Triumph 16
R TR2/3/3A Removal of Small Mouth Front Apron Triumph 4
jfarris TR2/3/3A Small Manifold Clamp Locations? Triumph 5
P TR6 Small pigtail wire Triumph 3
K TR2/3/3A Windshield frame Tenax fastners with small nylon spacers? Triumph 10
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
Tinkerman TR2/3/3A Installing small body stone guard Triumph 9
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
B Another small step for the 100-6 Austin Healey 27
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
P TR6 Small tear in convertible top Triumph 6
R water pump small hole does line up Austin Healey 7
A Project Small Axe Racing: Big Healey restoration/vintage racer build Racing 30
aeronca65t Small world...literally Other Cars 5
B Replacement of Small Black Wire inside Distributor Austin Healey 15
S TR2/3/3A small woodruff key Triumph 5
AUSMHLY Small world or what are the odds? Austin Healey 14
tinman58 General TR Small world Triumph 3
DanLewis And I thought the Bugeye was small... Spridgets 6
S TR2/3/3A small spring pan question Triumph 5
drooartz MGB-GT Other small progress MG 3
T TR4/4A TR4 Humps Big and Small Triumph 9
mailbox Air line for small shop Restoration & Tools 9
PC on road, on the [small] screen Spotted 0
L Engineering of "Big" healeys compared to "small" healeys Austin Healey 11
M TR2/3/3A It's the small stuff Triumph 11
Rob Glasgow Sometimes it's just the small things.... Austin Healey 3
jlaird Looking for a zinc plater for a small job Spridgets 11
T small site issue - geeks please help Triumph 4
davidb BJ8 small cracks in shroud Austin Healey 1
M Small details Triumph 26
toysrrus TR2/3/3A My `57 TR3 Small Mouth is Sold! Triumph 10
