Seven Clutch Again
CraigH
98 Caterham,1600 X flow, 4 speed. Needs a clutch replacement. I plan to pull the engine/trans this weekend.. no Problem, I think,,,,, but does anyone know a good manual on any of the specifics of the clutch dis-assembly/assembly....I am quite a amateur mechanic and alway like to have a reference.. Any help is greatly appreciated.
Regards
Craig
Its super easy.
make sure you drain the trans first.
Remove shift lever / remote
Pull the drive shaft.
Pull the radiator.
Unbolt the motor / trans
Disconnect the wiring, clutch cable, throttle & fuel, of course
remove motor, it helps to be able to tilt it up with a balance bar on your hoist.
Pull off the bell housing, and its all right there.
Its all held on my the pressure plate bolts around the perimiter of the flywheel.
Reverse process to reinstall
C Seven Clutch Lotus 4
D For Sale 2007 Caterham Super Seven Hayabusa 1400 Austin Healey Classifieds 2
a40bob Seven years later Other British Cars 13
M Austin seven ulster Other British Cars 17
regularman LA Seven Mary Three and Four Spridgets 1
DanNagy Spitfire Avatar Change - Spit or Seven? Triumph 7
Brosky Seven months of hibernation over..... Triumph 19
78Z Austin Seven Ulster 3D render Other British Cars 6
jlaird Seven min of spridget video Spridgets 3
S Seven Series IV Lotus 3
G Yeh, I know it's not really a Seven! Lotus 14
78Z My Seven is now a roller! Lotus 31
S 1971 Seven Lotus 13
jaybird Info on Super Seven Lotus 12
aeronca65t TRV Seven Lotus 1
G Lotus super seven 1964 Extra car to buy Lotus 1
78Z Lotus Seven restoration video Lotus 35
pbraun Wanted : Seven to buy Lotus 6
C austin seven dynamo brushes Other British Cars 7
Ed Sweeney Seven Shop in Oregon info MG 2
Sherlock New Lotus Seven kit car - Stalker V6 Lotus 4
J 2003 Caterham Super Seven Roadsport SV Lotus 15
TypeRboy Movies! - Lotus Elan and Seven! Lotus 1
Lutz Kramer Clutch Disengagement Austin Healey 14
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
