Dave
I am now putting the rocker shaft back together (after finding what i think is the problem, the reversed filter housing) and according to the workshop manual "a thrust washer is fitted either side of each rocker shaft bracket, and all springs, and rockers" although in your description above you do not have a washer either side of the shaft brackets, have you altered your shaft at all or is this the correct way ?
Rob
