Rocker shaft dis/reassembly
Moseso
The alloy pedestals on the four cyl. motors are a real tight fit on the shaft. Is one advised to heat them when removing/reinstalling them on a rocker shaft rebuild -- or just twist 'em off and on?
TR3driver
Great Pumpkin - R.I.P
I've always just twisted mine. Don't suppose a little heat would hurt, though, I've just never seen the need.
Tinkerman
Got to be careful with heat around aluminum. Melts pretty low. Like Randall, I just twisted mine on and off. The shaft doesnt move in the pedestals. Might put some WD-40 in there to assist with the twisting.
Good Luck, Tinkerman
DougF
Twist. I reassembled mine with Lucas Oil Stabilizer. It wasn't fun to work with, but everything was well lubed when finished.
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
D MGB MGB rocker shaft shims MG 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
DornTRoriginal General Tech Where is the Rocker Shaft Retainer Pin Triumph 2
TR6BobNF TR6 TR6 Rocker Shaft Assembly Triumph 1
B Rocker shaft spacing washers. Austin Healey 2
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
glemon Final Rocker Shaft Question Triumph 5
glemon Tuftrided Rocker Shaft Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
6 more about the rocker shaft Triumph 12
6 rocker shaft Triumph 3
L Rocker Shaft Assy Triumph 7
7 rocker shaft Triumph 2
T Defective rocker arm shaft photo Triumph 12
T Rocker arm/shaft question Triumph 13
BOBBYR Rocker shaft rebuild Austin Healey 10
H Rocker Shaft assembly Austin Healey 1
chicken Rocker shaft Austin Healey 3
B Rocker shaft problem Triumph 2
T Rocker shaft cleaning Triumph 19
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
M Rocker arm shaft question Austin Healey 11
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
C Rocker arm play on shaft Austin Healey 12
M Rocker Arm Shaft Triumph 4
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
