JimLaney
After cleaning up my rocker arm assembly, I discovered deep scoring in the rocker shaft. Couldn't find and cause in the bushes of the rocker and ordered new shaft from MM. Shaft came with plugs in both ends. I tried to remove the screw plug from the old shaft but despite PB blaster and heat, it would not budge. Do I have to remove one of the plugs from the new shaft and replace with the screw from the old shaft? If so, any suggestions for removing the the stubborn plug?
HELP!
HELP!
