Resource for Steering Pinch Nut?
Aldwyn
I have discovered that the pinch nut on my steering column is cracked. (Item #2 in the Bentley's manual, page 361)
None of the big three have it, and only moss lists it as all (but showing not available).
Anyone know where I can get one?
And should I drive the car if mine is cracked? /ubbthreads/images/graemlins/smile.gif
Thanks,
Aldwyn
DougF
I don't have my Bentley manual available now, I am looking at my BL Manual. Are you referring to the nyloc nut used to pinch the steering column adapter?
If so, these can be purchased at almost any hardware store.
You will need Grade 5, it is either 1/4-28 or 5/16-24. Take your sample with you to match.
If again this is the nut I am referring to, I would hold off on driving the car until it is replaced. It's not worth losing your steering at 65 mph over a $.50 locknut.
G
Dumb question. Just what exactly are you referring to? The actual clamping mechanism that squeezes over the upper steering column and has two bolt holes in it with which to bolt to the rubber knuckle actually has a "crack" in it where it squeezes together. If there is a crack elsewhere in this assembly, pitch it and resource another. You may have to check with one of the smaller vendors that have access to recycled parts. Doubt this part is available new. Have you tried Rimmer Bros.?
Aldwyn
Aldwyn
Taking a lesson from Dale, here are some photos:
The first giving a perspective of what we're looking at, and the second pic showing the crack on the unit.
Thanks!
Aldwyn
BritBox
Hi Aldwyn,
We're talking about the yoke-like fitting, right? I don't think yours is cracked. There is a "split" in the fitting to allow it to spread apart and let the splined shaft thorugh. I've had to pry it slightly with a screwdriver and then restore clamping pressure with the bolt and nyloc nut.
Yours looks different than the one on my TR250, but I would look at it closer to be sure if it's cracked or not. Hopefully, someone else will weigh in on this.
I'm back to cooking dinner. Good luck.
BritBox
Hi Aldwyn,
I found two different yokes out in my parts stash, one of which is exactly like yours. It looks irregular until you look at it from just the right angle--that's what happens when a cut is made diagonally into a compound curve. It's actually cut straight.
I took some pictures of the yokes, but my camera and computer are not talking to each other today, must be the holiday. Sorry I can't upload them.
If you had the yoke in your hand, you'd be able to see what I am trying to describe. Maybe if you slowly turn the steering wheel and look closely you will see it.
Hope this helps,
YankeeTR
I believe that BritBox is correct..it IS made that way...after all it IS a clamp and , for it to clamp, it has to have a gap.
I can see how it is confusing...but, if you turn the wheel and get another look, you'll see...
TRMark
Bronze
I would take a real good look at your flex couplings. Looks like they have not been replaced in recent years or ever. Mine looked like that on my TR4 when I took them off they were worse than I thought, shouldn't have been driving the car.
DNK
Might as well replace it. It is SO Much fun installing the new one
Aldwyn
Aldwyn
DNK, I detect sarcasm. /ubbthreads/images/graemlins/smile.gif
I may clean it up a bit, and move the wheel to see what she looks like.
Now... what's a flex coupling? Searing for it on TRF and Moss brings up nothing!
DNK
The flex couple was what I was funning about. It's the rubber thingy.
TRMark
Bronze
Sorry, its referred to as flexible coupling. You can find the diagram of the steering in the Moss catalog. The part you have been concerned about a crack is called an adapter. The flexible couplings are not difficult to replace. It is bigger hassle to get the adapters off the splined shaft. The flex has a larger bolt pattern than the adapter. You have to squeeze the flex coupling in a vise so holes fit the adapter. Don't know if you can replace it without removing the adapters, but you can bet someone around here does. The TR4 has two flex's, looks like the 6 has only one.
G
In my quest to spend as much money as I possibly could to replace near every part on my TR6 (or so it seemed), I tried for two days to replace the flexible coupling on my steering. Finally gave up when I determined the new "rubber thingy" ( I like that description ) was larger than the old one. Maybe that insert about the vice above was the answer, make it smaller by compression. TRF swore they sent me the correct one. I determined my old one was fine. ( It had actually been changed a few years before I adopted the car. )
The "crack" indeed is normal for the pinch fitting. Notice how it follows the design of the fitting, keeping the bulk of the metal away from the crack, if that makes sense.
Aldwyn
Aldwyn
Arrrgh! It's easy AND extremely difficult?
Maybe I will just leave it alone. /ubbthreads/images/graemlins/smile.gif
My main fear was the "crack" and since that fear has been alleviated, perhaps I should just leave well enough alone, and get back to the processes of fixin' what's broke, modernizing the car, and detailing the engine!
Coming up... breaks (fluid is dark brown, starting to feel pulses in breaking), sping on oil conversion, installing a modern stereo (cutting the center console), and depending on what is going on with my voltage issue... replacing the alternator.
Thanks again for the help, folks! It's greatly appreciated!
swift6
Installing the flexible couple is very easy once you know the trick. You can compress the coupling in the car using large slip jaw pliers or a large hose clamp. The flexible coupling is supposed to be in tension when installed.
I Light bulb base resource? Triumph 1
G Resource Triumph 0
I Resource for BMC/Leyland parts for Sprites? Spridgets 15
JPSmit MG T type resource MG 0
angelfj1 Bolts - technical resource Restoration & Tools 0
71tr useful resource Triumph 5
Sherlock The Unofficial Austin-Rover Web Resource - great website Other British Cars 1
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
