Rear Seat Pan Seal
big6
I am re-fitting the rear seats of the BJ7. British Car Specialists lists a rear pan seat seal in the rare and hard to find parts catalog. I did not find the rear seat seal in the AH mechanical service parts list or the Moss parts catalog. Is the rear seat seal required or is this a product enhancement?
If anyone is using the rear seat pan seal can you post a photo of the seat seal? Or a profile of the seat seal.
Thanks in advance,
Thanks in advance,
A lot of water gets kicked up in this area from the road so I would put a seal in to keep out the mess.
The same goes for the trans/floorboard seals. I seem to recall a seal when I first dismantled my car.
Big6
In the March-April edition of the Austin Healey Magazine there are tips on trimming the cockpit written by Roger Moment. I recently employed some of the tips recommended in this article with good results, including Roger's recommendations for rubber seat pan seals.
Roger recommended a rubber seal that can be purchased from Metro Molded Parts (www.metrommp.com), part #LP 41-M. The article also shows how to constuct a simple jig to create a small slit in the extruded seal to allow it to seat properly. Once done the seal fit perfectly.
You can order back issues of the magazine @ www.healey.org. That same site has a great Tech archieve section with many articles written by Roger Moment and Gary Anderson.
Good Luck,
Jeff
Hello big6,
Some parts do not need to be ordered from a specialty place, as in this is the hard to find part your looking for.
The rear seat just bolt into place. All that is needed is a soft water proof seal of some sort. Consider using a Camper Seal Self Adhesive Foam Tape Weather Strip that's sold at the local hardware store. When bolting down the seat, it will make a very good seal. All for about five buck.
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
D Rear Seat Side Panels, BT7 Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
J TR2/3/3A TR3 Rear seat Triumph 11
A TR2/3/3A Rear seat Triumph 9
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S BJ8 Rear Seat Side Panels Austin Healey 3
Jayplum TR2/3/3A Support for back rest rear seat Triumph 4
T Anchoring the Rear Seat Pans Austin Healey 15
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
S TR4/4A Rear jump seat Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
J TR2/3/3A 1957 rear seat carpet pictures Triumph 7
M TR4/4A Rear seat upholstery assistance please. Triumph 2
rjc157 BJ7 Rear seat Back Austin Healey 5
T TR2/3/3A TR-3 Rear Seat Millboard Triumph 9
B Rear seat backrest pictures Austin Healey 6
S rear fold down seat Austin Healey 4
L Rear seat belts Austin Healey 26
M Rear Seat Austin Healey 2
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
H holes rear seat area Austin Healey 7
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
maxwedge5281 rear seat pans for bj7 Austin Healey 2
J TR2/3/3A How to attach rear seat tabs to anchor the seat back??? Triumph 2
O Rear Seat back Removal British Motor Corp 0
C BJ8 Rear Seat Back Carpeting? Austin Healey 3
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
Frankenhealey Optional rear seat for a Frogeye? Spridgets 10
G Removal of rear seat pans Austin Healey 16
H rear seat pans for 4 seater Austin Healey 3
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
GregW Rear Seat Dimensions Austin Healey 7
Gordon_Dedrick TR 3 occasional rear seat Triumph 4
L BJ 8 Rear seat belts Austin Healey 2
ekamm TR2/3/3A Rear seat tr3a Triumph 4
longbridgehealey rear seat pans for 100-6 Austin Healey 26
HealeyPilot Rear seat belt for 1960 BT-7 Austin Healey 9
chicken what size should the holes be to take my rear seat Austin Healey 9
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
chicken BJ7 rear seat pans Austin Healey 0
