Rear hubs on a BN1
catfood
Anybody out there able to advise? I'm just about to start dismantling the rear axle on my BN1. Can the hubs be removed without the special tool mentioned in the manual? If so how?
Thanks
Take the nut off, etc. to remove the axle. I then turn the axle around and place it on the studs, leaving space for a socket to push against the rear housing where the large nut was. Using washers and the lug nuts, the axle can be used as a puller, drawing the hub off the rear casing as the lugs are evenly tightened.
Bob
"I then turn the axle around and place it on the studs, leaving space for a socket to push against the rear housing where the large nut was. Using washers and the lug nuts, the axle can be used as a puller, drawing the hub off the rear casing as the lugs are evenly tightened"
Can we assume by 'axle' you mean the half shaft? Good idea, I've made a note of this method.
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
G Noisy Rear Hubs Austin Healey 6
Raymond MGB Rear Wire Hubs MG 6
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
R Rear Hubs/bearings Austin Healey 25
D Rear Hubs Renewed. Austin Healey 0
J Rear splined hubs AH3000 Austin Healey 4
brohawk TR6 Grease on rear hubs Triumph 8
W TR6 tr6 rear hubs Triumph 3
J TR6 rebuilding tr6 rear hubs Triumph 13
Jeepster Rear hubs colour Austin Healey 3
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
t_bush Spitfire Spit rear hubs, Arrrgh! Triumph 6
Gliderman8 Rear hubs... new or rebuild? Triumph 27
eschneider Spitfire another Spitfire question - stuck rear hubs Triumph 26
R Rear Bearing Hubs Spridgets 0
drooartz Assembling rear hubs -- do I have this right? Spridgets 5
Maccers Leaking rear hubs on BN4 Austin Healey 6
G Stuck rear hubs Triumph 5
T TR6 tr6 rear hubs Triumph 4
J rear hubs...Something I can rebuild myself? Triumph 24
guzzul Spitfire Spitfire rear hubs - where to position bearing? Triumph 6
jerrybny when to rebuild rear hubs Triumph 3
W Rear hubs Triumph 5
W Rebuilding rear hubs Triumph 11
jerrybny Rebuilding rear hubs Triumph 8
Basil Slight problem with rear hubs [EType] Jaguar 7
T TR6 TR6 rear hubs Triumph 3
T Small crack in rear hubs Jaguar 4
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
