Rear bump stops vs springs
CanberraBJ8
Hi all
As many people with BJ8s seem to have done, I have opted for older model rear springs in order to position the rear lower to the ground for a more attractive look, and also more importantly as i was getting tire-to-body rubbing while cornering (due to wider than original tires).
It has been noticed recently though that there is not much travel before the bump stops hit- with the bump stops for a BJ8 fitted and springs for earlier models.
Has anyone else encountered this problem, and if so, what remedy?
The guy who did my last wheel alignment suggested trimming the bump stops a little to increase the travel?
CanberraBJ8 said:
Hi all
I bought new springs for my BJ8 to make it sit level. I plan on trimming the rubber bump stops to take care of that problem(already thought about doing it after I saw the distance between the bump stops and frame). I'm doing a frame up and it'll be a few more months before the engine goes back in and then after all the pieces are back together I'll make the adjustment.
Can anyone tell me the amount of travel normal is present with the <span style="text-decoration: underline">older</span> springs with the <span style="text-decoration: underline">older</span> type of bumpstop?
Rather than cut the top off the bump stops it's better to cut a few V shapes into the rubber so that it's a gentler stop than a bump. A tip given to me by Paddy Hopkirk who said it also improved the handling in extreme situations.
B Rear bump stops Austin Healey 3
PHerder Rear rubber bump stops removal/replacement? Spridgets 1
T BN1 Rear Bump Stops Austin Healey 10
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR4/4A Rear Bump Stop Spacer Triumph 1
bugedd Rear axle bump stop Spridgets 7
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
D MK2 rear axle "Bump Steer" Jaguar 4
G Rear Bump Box Austin Healey 4
6 Bang in rear when going over bump Austin Healey 14
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
L For Sale JAGUAR E – TYPE: IRS REAR AXLE (EARLY), 2,88:1: Jaguar Classifieds 0
L For Sale AUSTIN HEALEY: REAR AXLE Austin Healey Classifieds 0
L For Sale AUSTIN HEALEY: REAR AXEL WITH DISC BREAKS Austin Healey Classifieds 0
Y MGB Possible rear axle issue? MG 0
jfarris For Sale TR 2-4 16MM (5/8”) Rear Sway Bar Triumph Classifieds 0
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
B MGB Brakes scrapping sound from rear brakes on hard left or right turn. New wheel cyl, drums shoes ? MG 2
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
71TR6 TR2/3/3A TR3A rear shelf carpet Triumph 6
DornTRoriginal Wanted TR3B Left rear fender Triumph Classifieds 7
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
