Ratco cable linkage - diagnostics
T
Tinster
I think I have left the impression I have a problem with Tony's
very fine Ratco cable throttle linkage. If I have,
that is a blunder on my part. Tony's product is excellent
and a great addition to my bucket of bolts TR6.
I am calling it the "Ratco" project for lack of a better
heading.
Yes, my warm engine idle is higher than normal after
installing the Ratco.
But I think some other process is at work causing this condition.
And as I stated, a 1200 RPM idle bothers me very little.
So I intend to fully sort out my gas pedal to carb linkage
and try to determine the cause of the 1200 warm idle.
Any suggestions are welcome. I'll start at the gas pedal itself.
Tony! If I left the impression I was not satisfied with
your roduct, I am sorry. Your cable throttle linkage is
awesomely responsive.
I'll report findinds as they occur.
dale
90% SUCCESS!! 1200 RPM warm idle reduced to 900 RPM.
Taking the advice of several "real" Triumph experts,
I started system diagnostics at my gas ped and worked
forward toward the carbs.
Truthfully, it seemed a waste of effort since my entire
gas pedal to carbs is brand spanking new.
1. Gas pedal A-ok, returns instantly.
2. I lubricated my brand new throttle shaft bushings
and gas pedal still returned instantly.
3. I lubricated the Ratco cable mount- gas pedal returned instantly
4. I lubricated the new carb coupling- gas pedal returned instantly.
5. I checked carb choke cables- both appeared functional
1. Cold engine started on 1st crank, 1/2 choke, standing outside the car.
2. Car warmed to 160*F, idle at 700-800 rpm
3. I goosed the gas pedal- warm idle settled in at 1200 RPM.
4. Huuummm?
5. I disconnected the new Jeff Palya carb linkage.
6. Idle dropped to 800 rpm.
7, Reconnected carb linkage - warm idle shot to 1200 RPM
8. AH Ha- the culprit has been found!
9. Removed the carb linkage once again but this time,
I used two 1/4" sockets to tighten the four bolts and backed
the carb throttle shafts into neutral when the carb linkage
bolt threads slightly moved the carb throttle shafts forward
as they turned.
I can certainly live with 900 rpm idle and I love the response of the Ratco system.
ANOTHER small worry put to bed.
dale
dang- I'll miss all the Ratco post now.
Good job mate
Congratulations.
If I read this correctly you have just synchronized you carb throttle shafts and adjusted the idle in the proper manner.
900 RPM is fine for any stock TR6.
Leave it alone. Do not start with the vacuum gauges now that this is over.
Get in car and take Wendy for a longgggggggggggg ride, followed by a stop at your favorite biker bar for a few cold ones.
May the sticking idle issue rest in peace..............forever..............
...and ever. Amen. :angel:
I chime in my prayer of thanks and wishing you, Dale, (and all other
Forum members), a very Happy and Prosperous New Year.
Happy cruising, Dale.
T Ratco carb cable linkage Triumph 21
T Ratco cable linkage review Triumph 5
Brosky Ratco Cable Linkage install on Tri-Carbs Triumph 16
C Ratco cable help? Triumph 12
T Ratco Cable + Heat shield Triumph 30
Brosky Ratco throttle cable installation Triumph 2
F TR6 RATCO fuel injection Triumph 4
martx-5 General Tech Ratco Article Triumph 1
DNK Info About Ratco Triumph 12
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Tabcon I have been RATCO-ized...finally! Triumph 17
T Ratco high RPM idle part two Triumph 11
T Ratco Linkage PART TWO Triumph 15
martx-5 Tony's [RATCO] High Idle Triumph 16
T Gorilla Cross Member from RATCO! Triumph 14
D Ratco Throttle Linkage Triumph 8
B Anyone used Ratco shock in spring set up? Triumph 0
D Ratco Throttle Linkage Triumph 31
Brosky Throttle linkage from Ratco Triumph 35
michalotti_tr TR Frames - RATCO now has website Triumph 39
J BJ8 Choke Cable - Plastic Covers Austin Healey 5
Y MGB Positive Battery cable? MG 7
A Handbrake Cable Routing Austin Healey 6
B Replacing the Handbrake Cable Austin Healey 8
KVH General Tech Heater control valve/cable Triumph 1
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
D BT7 Air Vent Control Cable Routing Austin Healey 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
Bayless Help please installing bonnet release cable Spridgets 8
B tachometer cable has a hole in it Restoration & Tools 7
D Choke Cable Length Austin Healey 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
R Bugeye heater cable Spridgets 12
George Zeck Speedo Cable? Spridgets 3
steveg Battery Cable Specs Austin Healey 33
Walter74 Throttle Cable Conversion Austin Healey 6
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
P TR6 Jumpy Speedometer cable Triumph 4
E Oil leaking from the Tachometer cable Austin Healey 5
TomMull TR2/3/3A Which choke cable Triumph 12
P TR6 72 TR6 Speedo cable Triumph 2
S Routing of Hand Brake Cable Austin Healey 6
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
T TR6 TR6 Choke Cable Lubrication Triumph 5
