I started to install my new Ratco Throttle Cable last night and I made a few observations which have me wondering if I'm doing it correctly. My car is a 73 TR6 with the stock carb setup (2-ZS). What I noticed that has me wondering is:
-when the firewall bracket is installed where instructed it is not directly in line with the carb bracket, front to back. The carb bracket is definately more outboard so that "lazy droop" angles a little towards the outside. I don't see a problem but in the pictures I've seen it looks front to back. Will this be a problem?
-I have the carb bracket mounted on the rear carb. When I attach the new bell fastener (the one from the end of the new cable) to the spring couplers it does not line up over top of the bracket. I would think that it would be better if the pulling force on the couplers would be directly over the cable mounted in the bracket. I hope I've explained that correctly. It looks to me from pictures that the cable end fastener should be directly over top of the bracket, correct? Have I done something wrong?
-the part that holds the bell fastener and the couplers and attaches to the throttle shafts is from the old mechanical linkage, right? The piece with the notch?
Thanks for any advice.
