Pros/Cons with 7,5 clutch?
Aggudabbu
Hi,
I'm currently stocking up on the parts i need to do a ford five-speed conversion and now a have everything i need except a flywheel and clutch.
And now my question is this, since modifying my old flywheel would be kind of expensive so i though of buying a modified one with clutch i wonder if there is any disadvantages on going with the bigger alternative 7,5inch clutch compared to 6,5 or the old ford clutch?
Will be using my car for fast road by the way.
And if anyone might have a modified flywheel for sale preferably without ring gear do send me a PM.
//REGARDS Alex
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
M TR2/3/3A Alloy valve cover. pros/cons Triumph 6
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
sundown TR6 pros and cons of zinc additive Triumph 6
Bremer TR4/4A 92mm bore engine pros and cons Triumph 9
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
D Spitfire MKII cam in a MKII '65 Spit - pros and cons Triumph 2
TulsaFred MGB-GT Pros and cons on MGB GT as a project? MG 4
jjbunn Wire wheels vs. steel - pros/cons? Jaguar 15
M Pros/cons on e-bay item Spridgets 19
Luke_Healey Pros and cons of various carburetors? Spridgets 54
S Silver Shadow for daily driver? Y/N? Pros/Cons? Other British Cars 23
SCguy Wedge TR8 Air Conditioner Removal Pros/Cons Triumph 13
vping Pertronix - Pros & Cons - Video & Pics MG 198
TNMGB Antique plate pros and cons? MG 14
S Wedge Potential Buy: Pros v. Cons of 1980 TR7 injected? Triumph 7
D MGB Pros and Cons of an MGB. MG 9
B Question for the paint pros Triumph 8
Lutz Kramer Clutch Disengagement Austin Healey 14
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
