Hi all,
I tried to set the timing on my BT7 today using my strobe (15 degrees BTDC at 600rpm). The problem is that I can only get up to 8 to 10 degrees by rotating the distributor as far as it will go clockwise and turning A-R knob on the dizzy as far as it will go. I have checked the timing at 3000rpm which is around 20 degrees.
I am at loss. So far I haven't gone back to check the static timing?
Any advice welcome.
Phil
Any advice welcome.
Phil
