    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
POR15 and cage nuts
TexasKnucklehead
I'm thinking of using POR15 on my floor and trunk pan, inside and out and am concerned about the cage nuts. I fear the coating might fill the nuts and could stick the nuts to places they don't need to be. If I put bolts into them, the bolts may become difficult to remove with the coating. I don't know how anyone gets the nuts and/or surrounding area covered without making a mess of it all. I don't want to have to replace cage nuts after it's painted.
Any suggestions are welcome.
I used POR15 on the underside of the floor pans and put bolts in the captive nuts and made sure I didn't paint them shut.
On the inside you should be able to do the same thing, being careful. I actually sanded away the slight surface rust on the inside of my floor boards, then primed and painted to match the body (or real close). That all got covered up with jute and new carpeting, so I didn't feel POR15 on the inside was all that critical.
I had just one or two more heavily rusted areas, and there I sanded and applied "Rust Mort."
just antisieze the bolt threads, put them in befores POR and remove them after. POR won't stick to antisieze.
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
S TR2/3/3A the self of POR15 is and how to apply POR15 Triumph 11
J herculiner over POR15 for underside Restoration & Tools 13
Basil por15 for gas tank Jaguar 12
S Picklex20 and por15 don't mix MG 1
J painting over por15 - advice needed. Restoration & Tools 7
J My two pieces of POR15 advice Restoration & Tools 0
Stewart I hate por15 MG 9
Brosky Frame stripping and POR15 pictures link Triumph 2
Brosky Up-date: Frame stripping and POR15 painting Triumph 30
G Issues with POR15 Triumph 22
ncbugeye POR15 Fuel tank repair kit Restoration & Tools 6
A RUST: Eastwood, POR15, KBS or ??? Austin Healey 8
H Painting over POR15 Restoration & Tools 4
T MGA MGA fender removal for POR15 treatment MG 5
C HEALEY GREEN ENGINE ENAMEL-POR15 ??? Austin Healey 33
milemarker60 Powder Coat or POR15 Frame? Triumph 11
Tim Tucker Rust Treatments: Por15 vs Rust Bullet Restoration & Tools 9
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
D TR2/3/3A Cage nuts, attachment Triumph 6
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
DornTRoriginal General Tech Starter Mounting "Cage Nut" Delima and Poloshing Cost Outrage Triumph 27
5 roll cage designs Austin Healey 12
jjbunn Bonnet and heater fan squirrel cage Jaguar 8
EVSpriteGuy Where to get a reman 1275 rib-cage tranny? Spridgets 15
AweMan Cage nuts Triumph 8
B New Canvas Cockpit / Cage Cover Spridgets 13
D TR2/3/3A TR3 Cage Nuts Triumph 11
tony barnhill Roll Cage & Fuel Cell in MGB GT Racing 10
B CAGE PICTURES!!!!!!! Racing 9
B Looking For ST-7 Cage Pictures Racing 28
tony barnhill MGB GT Roll Bar/Cage Racing 2
M roll cage for Mk II sprite Spridgets 2
T building a NHRA legal cage Racing 6
G TR3 roll cage Racing 10
RobSelina Roll Cage Side Protection Spridgets 21
RobSelina 1500 Midget Weight [Roll Cage Considerations] Spridgets 8
R Rear suspension cage-420? Jaguar 0
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
tr6web TR6 Need advice removing downpipe nuts Triumph 4
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
S TR2/3/3A ÂĽ fine square nuts Triumph 7
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
shadowfever Midget seat nuts and bolts Spridgets 2
A BN7 Front Hub Stud Nuts Austin Healey 5
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
Z Lug nuts for Minitor rims Spridgets 1
