I noticed my left front parking light wouldn't come on. Right front was okay. Turn signals okay.
Opened the cover, tested the bulb - okay. Tested the double connector inside the bulb holder - not okay. Plastic base was broken, so one of the two connectors (I assume the parking light circuit) actually was touching the ground (base).
I pulled the unit to replace, and realized I hadn't marked which wire was which. Of course, all three are red, connected to the harness with wire nuts.
So I used my multimeter to try to figure out which wire was which. Pulled on the parking light switch, right front parking light comes on. I connected one multimeter lead to the bumper (ground) and the other lead to one of the red wires.
The multimeter showed 12 volts - but the HEADLIGHTS came on also. And stayed on even after I removed the multimeter leads.
I turned off the parking light switch, and the headlights (and right front parking light) went off.
Pulled on the parking light switch, the right front parking light and both headlights came on.
Pulling the light switch to the second notch (headlamps) changed nothing, returning to parking lights changed nothing. Only pushing the parking light switch full in (off) turns off the parking light and headlights. Ignition key is off.
As I also discovered my new parking light unit won't accept the old glass cover and chrome bezel, I'm not a happy camper right now. Are there some front parking light units which won't accept the Lucas glass cover and bezel?
Is there a secret chant I can utter to remove the headlamps from the parking lamp circuit.
Argh.
Tom
Argh.
Tom
