TR2/3/3A 3D printed tail light
DavidApp
Messages
4,972
Reaction score
398
Some time ago I saw a thread about a 3D printed tail light assembly. Not the red or amber part but the bit that holds the bulb. The guy had made it so an LED could be used.
Having been gifted a 3D printer I was interested in attempting this mod.
Does anyone know where I can find the info?
David
mastaphixa
Bronze
Messages
233
Reaction score
23
Brilliant
DavidApp
Messages
4,972
Reaction score
398
Thank you.
That is exactly what I was looking for.
Now to see if it would work on a TR3A and if my CAD skills are up to the task.
David
DavidApp
Messages
4,972
Reaction score
398
I am using FreeCAD but I am just getting a handle on how to get it to do anything that I want. So far simple shapes are all I have managed.
David
Frank Canale
Messages
559
Reaction score
32
I am giving fusion 360 a try and just getting started trying a simple sheetmetal part. Slow going for me also. Frank
CJD
Messages
7,006
Reaction score
417
That looks like a nice platform. It takes a little practice to "think" in the way cad programs think, but once you understand the process it opens up a whole new world. I have experience with fusion, which is a version of Inventor with a few features removed.
The latest cad designed ground up for 3-d modelling is completely different than the old 2-D programs we used. The thought process starts with basic shape...then extrude it...then modify it. Once you change the order in your mind, it works much better. The CAM, or machining and printing interfaces are a whole 'nother story!?!
DavidApp
Messages
4,972
Reaction score
398
The thought process is a bit off. I was trying to make a coffee scoop so I thought I had drawn a cylinder with a bottom in it but it printed a tube. After a bit of YouTube study I found a way to do it. You draw a half section of the part then rotate it. Worked great.
David
CJD
Messages
7,006
Reaction score
417
Or...you can draw a smaller circle on top of your cylinder, and then use that to cut out the inside to just short of the bottom of the cylinder. There are dozens of ways to accomplish the same final object!
Snowkilts
Messages
157
Reaction score
4
You can also get "right angle" LEDs that are drop-in replacements for the existing bulbs. I have them on my TR and they work well. Available for both positive and negative ground.
You would still have to make some wiring changes to get the mod described in the video, but you need to do that either way.
Edit: No wiring changes are required for my later ('60) vehicle, but of course I do not have a "third" stoplight.
equiprx
Messages
1,740
Reaction score
250
Anyone here able to 3D build a flange I need?
It's not at all car related and doesn't need to be very strong.
The overall size is 80 mm round by 30 mm thick.
It's only an adapter ring for mounting a microscope.
All other fabrication sources have declined my requests.
CJD
Messages
7,006
Reaction score
417
The printing is not hard...it's the programming that takes the time and makes it non-profitable! If you can learn Fusion 360, mentioned above...you could program the part, and then I bet someone will take up the job for you.
I used to advertise laser cutting. I wound up with a big following, because I was not charging for the programming, only the 15 minutes or so of cutting. For that 15 minute cut job I would often spend 20-30 hours on the computer! My last job was a gentleman who was building a 100" wingspan Consolidated PBY (the old WW2 float plane). I worked with him on and off for 4 years, spent over 500 hours programming the entire plane, and only got $50 for one cut job. I finally shut him down. He still writes every couple months. I explained that for a 1-off part (plane in his case), you can hand cut balsa much quicker than I could program the laser to cut it. The advantage of the laser, or 3D printer, is the follow-on jobs are near effortless.
aeronca65t 3D printed Bugeye Spridgets 18
S TR2/3/3A Pinion tail bearing replacing Triumph 12
bigjones TR2/3/3A Rear tail light not budging Triumph 5
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
O Spitfire Tail lights not working Triumph 6
T Tail light extension Spridgets 2
drooartz MGB Early tail lights on later car MG 17
JFS Wedge Brake and Tail lights Triumph 3
R bugeye tail lights Spridgets 6
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
C MGA R/H tail lamp removal on a 1962 MG 5
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
N Wanted Early rear tail light lens Triumph Classifieds 0
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
L TR2/3/3A Rear tail light cutouts Triumph 213
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
B Stop/Tail light wiring Austin Healey 23
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
RandyInUtah Wanted TR3 Original Tail light lens Triumph Classifieds 1
F TR2/3/3A Tail Lights Triumph 3
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
S TR2/3/3A outer sill and fan tail Triumph 11
K TR2/3/3A Ck Technologies tail light blinker? Triumph 3
T Auburn Boat-tail Speedster Spotted 3
M TR6 Tail Light sockets Triumph 1
M Tail light sockets FORUM Navigation Questions 1
M MGB Tail lights do not work- 1977 MG 8
M TR2/3/3A Tail pipe finisher [extension] Triumph 13
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
R Tail light wiring ??? Austin Healey 5
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
D Help! No tail lights or sidemarkers Jaguar 14
B Tail pipe chrome attachement to look nicey nice?? Spridgets 28
R smoke out of tail pipe Spridgets 46
C tail light Austin Healey 1
Got_All_4 Wedge TR7 tail light gasket Triumph 5
I LED tail light suggestions? Spridgets 22
Darrell_Walker tail light reflectors -- chrome or white? Triumph 7
Morris Deffective tail light assembly? Spridgets 6
bighealeysource LED tail lights for Healey's and most Brit cars Austin Healey 7
M TR2/3/3A TR3 Tail light question Triumph 4
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
CJD TR2/3/3A TR 3A Tail Lamps Triumph 6
S TR2/3/3A tail pipe tr3 Triumph 6
G No left tail light Spridgets 2
K Tail lamp wire connectors? Triumph 15
Top Bottom
