All 4 parking lights dead, fuses all good?
RickB
Today I was told my tail lights were not on, after looking I found my front parking lights also not on.
All turn signals work fine.
Brake lights also work.
Now I'm confused, what could it be?
Like I said in the title, all fuses are good.
Bad light switch/loose terminal on switch.
Ugh that's what I was thinking too.
There isn't anything for that going through the turn signal switch is there?
That wouldn't make sense because my turn signals all work.
Turn signal lights are a different circuit. Have you had your hand under the dash recently for anything? It may just be a wire pulled off. The light switch is easy to pop out and clean up.
Well I figured it must be the light switch.
Got it out and put the digital meter on it and.... Nope it's good!
Okay, once again around. One loose wire in the boot - ok.
No voltage to the tail light wire.
Hmmm...
So up front again and - apparently I didn't look properly at ALL of the fuses.
Replaced one fuse and Robert's your mother's favorite brother!
Glad you have it sorted. I was about to suggest that you also check the fuse for corrosion. :smile:
I forgot that I had that circuit off on it's own fuse, until I saw the wire color on the switch.
It would be nice if I remembered the color code, maybe the new oldtimers drugs that will be hitting the market soon will boost my memory... :smile:
K TR2/3/3A More electrical....parking lights?... Triumph 2
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
B How to install tail and parking lights?? Austin Healey 10
19_again bright parking lights MG 6
V 1969 Mini Parking Lights British Motor Corp 6
fmichaels 67 parking/turn signal lights Spridgets 8
10musketeer Hmm. Parking Lights Spridgets 4
W Parking Lights Spridgets 12
Bruce Bowker Parking lights Other Cars 12
D TR2/3/3A wiper motor parking? Triumph 17
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
D Parking Brake Adjustment Austin Healey 2
M Windscreen Wipers Parking Spridgets 4
tr6nitjulius General TR TRIUMPHest 2019 Register# Reserved Parking Space# Triumph 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
S TR2/3/3A Wiper Motor Parking Question Triumph 8
TomMull TR2/3/3A Parking brake cable length Triumph 3
B Mini Windscreen Wiper Parking British Motor Corp 3
T TR2/3/3A wiper motor parking Triumph 7
T TR2/3/3A TR3b parking lamps Triumph 2
wingsandwheels TR6 TR6 wiper motor parking Triumph 1
T T-Series TF Parking Brake Disassembly Advice Needed MG 2
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
PatGalvin Parking Brake Rebuild Triumph 5
Brooklands Seen in the public parking garage in St Augustine Jaguar 4
Morris OT: Spent the night in a parking lot... Spridgets 2
tweety Parking Brake Adjustment Spridgets 3
M Wipers parking in the Up position Spridgets 11
D Front parking lamps and side markers? Triumph 10
Newkie Parking and Headlight problems MG 8
PeterK Well, the parking brake works ... Triumph 12
Dadandson Adjusting the Parking Brake Spridgets 12
tony barnhill Harbor Freight Parking Lot Sale... Restoration & Tools 27
Aeroken Parking Brake Cable Triumph 6
NutmegCT TR2/3/3A Parking light fun - TR3A Triumph 38
jjbunn Windscreen Wiper Parking MG 10
Russ Austin Wife's not happy, No parking space! Triumph 8
J Hand brake/ Parking brake MG 6
J Parking lot races Triumph 15
A parking break? MG 2
C Parking Light/Tail Light Problem Triumph 5
zoohow TR2/3/3A lights in series Triumph 2
tahoe healey Wiring Diagram for Fog Lights Austin Healey 13
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
Jcape Lights Spridgets 2
A 100-6 Brake Lights Austin Healey 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
