AUSMHLY
I was running redline in the tranny. No problems...it seems.
Then the overdrive stopped working.
Mechanic said, drain the oil, rinse with a gallon of gas then put in Castro 20-50. I did. Overdrive started working...for one day, then same problem of not going into overdrive.
Today I drained it, rinse the tranny with another gallon of gas and used Castro GTX 20-50 again. Overdrive is not working.
With the car parked, I turn the key to on, not starting the car. I flip the overdrive switch and tap the stick shift to the right and hear the clicking noise. Some times it does not make the noise. I think I have an electrical problem, connection or part maybe?
What do I do now?
Thanks guys.
Roger
What do I do now?
Thanks guys.
Roger
