Oil Pressure Too High?
John Kuzman
Finally, a decent weather day to take the BJ7 out of winter hibernation. Among other projects, did an oil/filter change over winter. Have the spin-on adapter. Used a NAPA Gold filter for the first time. (used a M*** supplied filter previously). Started engine, oil pressure reads 60+ at about 900 RPM, goes to nearly 80 under acceleration. When up to running temp., reads about 40 at idle, 60 under load. Prior to this oil change, readings were just about book spec. of 50 cold idle, 25-30 running temp idle. Oil is the same as always, 20-W50. Could the NAPA filter affect the system pressure? Anti-flowback in filter causing pressure increase? Are these readings I am seeing a reason to be concerned? Thanks.
Hi John,
Yes, some filters do have more restriction than others. Since the oil pressure pickup point is downstream from the filter, less restriction in the filter would cause higher gage readings. The pressure regulator bypass spring calibration could be a bit on the high side but I wouldn't worry about it. The regulator plunger may be sticking a bit, you could try removing it & cleaning things thoroughly.
Your pressures of 40 & 60, oil hot, are exactly the same as my BN2 with 20-50 hot oil & a K&N # HP-2009 filter.
Dave-
Thanks for the reply. I may follow your suggestion and clean the by-pass just to see if it makes any difference.
John
6 too much oil pressure??? Triumph 25
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
J Oil Pressure Too High Spridgets 3
Ed_K Can oil pressure too high damage something ? Austin Healey 4
M BJ8 oil pressure too high? Austin Healey 1
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
