TR2/3/3A New Top Too Tight
TomMull
My pre 60k TR3A came with a new Robbins top. Bottom line is that it's way too tight. I know from the past that these tops are a bit of a struggle but mine is at the point where it is not practical.
The last time it went on, early this spring, it took me, my wife and a heat gun half an hour to get it snapped. I left it on over the summer hoping that it would take a better set after time and sunshine. No better now. I had to use pliers on the tenax and a plastic trim lever under the lift dots when I took the top off yesterday. I admit my fingers are not as strong as they used to be but the old top, which came with the car, goes on and off in a jiffy.
I think the Robbins (and maybe all the current production tops) come without the fasteners attached. Perhaps the installer made things a bit tight when it was fitted as would be correct for a conventional convertible top that is stretched a bit by the frame.
Any suggestions? Seems like someone suggested leaving off one of the webbings in an earlier post on this topic. I also tried installing the top with the bottom stick pivots collapsed, which makes the top go on easily but I was unable to raise the pivots with the top snapped in place.
Tom
Tom - I did not attach the webbing to the rearmost frame section - I keep the frame lowered when attaching to the windscreen, then I raise the frame, and finally slide the rear frame member in place. Might be worth a try for you.
Thanks Randy, easy enough to try and certainly cheaper than another top. The top itself would be the only thing holding the front frame in position? The rear bow looks like it will be held by the angle in the top.
Tom,
Might you be putting the top on "the hard way"? I have a friend who has had TR3's for more than 30 years and complained about how hard and long it took him to put the top up. He said it took about an hour. I showed him that I did HIS top in about three minutes or less.
The best way to put the top on is to bring the convertible top bows up and spread them then push the bows down at the "knee" in the frame linkage so that the bows are just above the rear of the seats. Then put the top over the car and fasten the front and back snaps/ lift -the -dot pegs and such. Then get into the car and pull the frame bows forward at that "Knee" to push the bows up and against the convertible top. Done. If the top is real tight then when you try to pull the frame up at those knee joints you may have to push on one side and then alternate back and forth to get it up. Or if you have a helper then one person on a side will either do it in one push or again one side push and then the opposite side push. I have never had to find an alternate method of getting those "knees" pulled forward but I would guess with my old age I could try to figure out some method / tool of standing on the outside of the car and reaching in to grab the "knee" and full it forward. I would guess in that case it would strongly benefit you to have two people working together to uniformly bring up the bows. One other thing that has worked over the years for me is to --while sitting in the car instead of working those knees forward is to reach up and pull up and forward on the front bow of the frame. You may find some combination of working the knees and the top bows to get the frame to its final position. But working the bows after the top is snapped in place is the best method.
Charley
I have done it the same as Randy for 45 years with many tops, some tight, some not so tight-the method works either way.
Tom-
the webbing is still attached to the two front bows and the rear cockpit so the frame stays upright while you put the top on. Basically it's how Charley describes, only the rear bow is tucked in until the knees are in correct position. I'd stay with Charley's way and only loosen the rear bow if a little more flexibility is needed for the top. It takes a little pushing to position the rear bow but it stays in place with the top seam.
I have a Robbins top that is tight, and use Randy's method, also leaving the rear bow loose and pushing into position afterward. Works out fine.
I too will second the motion on leaving the aft bow free from the strap. With the top secured fore and aft, straighten the knees to get the front two bows in place. Then coax the aft bow under the seam. Once in place it doesn't seem to move any.
The problem I had with the Robbins top that I bought new had to do with the two outboard fasteners on the windscreen. I installed all of the fasteners according to the tips and techniques that were provided from the many good folks on this forum. The top stretches out nice and tight. But I never have been able to stretch the forward corners out far enough to install the fastener to join up with the Tenex on the windscreen. So far, it doesn't seem to matter that the corners aren't fastened. But then again I'm not pushing 90 on the freeways.
Back in '62, the dealer I bought my new TR3B from demonstrated Charley's method as the proper way to install the top. I used it then and still use it now.
I did not mention the removal of the top. Again just go inside the car and push back on the "knees" to release the pressure and drop the bows. With all the tightness off the top you can just lift the fasteners.
Charley
Jeez, I've had my car over 13 years, and have put the top on and off exactly once.
Thank you all in advance for the next time I have to put in on, now I will know the proven way.
BTW, I've had the steel top on exactly never.
Thanks all. I will be busy cleaning hood stick joints today. I did try Charlie's method but was unable to push the pivot up with the top on as the joints were quite sticky. Will give that one another try.
Tom
PS: Kevin, Let me know if you ever want to sell the hard top. I'm sure it would get more use here in New England.
T
Put the top up today for the first time since June. Took 3 guys to help push it forward. It's now up until next June. British tops....
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H top trunnion too tight Austin Healey 3
regularman Metal strip that top fastens too Spridgets 2
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
