new spring question
Dan76spit
hi all,
got my new rear spring today from bpnw and am wondering if it matters what way it goes in. The manual says the clips are stamped front but they are not and neither are the clips on the original spring i took out. Manual also says about facing the ground edge of the main leaf towards the rear; i'm not sure what that means; both edges look rounded. The spring looks the same on both ends but i'm not sure how to tell what way should face the front. thanks...
Got_All_4 TR5/TR250 Spring question Triumph 1
D Rear spring length question. Austin Healey 6
warwick-steve How low is too low? [spring question] Austin Healey 19
CessnaTPA Carb Spring Question Austin Healey 7
D MGB another spring question MG 1
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S TR2/3/3A small spring pan question Triumph 5
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
J Rear Spring question ?? Triumph 6
Tr3aguy Spring question Triumph 1
D Spitfire spitfire rear spring question Triumph 2
C Spring is here, alignment question, and gearbox Spridgets 7
H TR2/3/3A TR3 Rear Spring Question Triumph 7
B TR2/3/3A TR3 spring install question Triumph 2
Atrus Leaf Spring Front Bushing question Spridgets 6
healeynut Sticky Valve/guide/ spring question 100 Austin Healey 4
RandallRK Clutch return spring question- BN1 Austin Healey 2
JPSmit Rear Spring Bracket Question Spridgets 14
svtmikey Spring question Triumph 4
JPSmit Tonight's Question - shocks [and one spring] Spridgets 14
JPSmit Front Spring Question Spridgets 7
JPSmit Quick Spring Question Spridgets 10
TR_Jim Spitfire Spit & GT6 Rear Spring Question Triumph 10
M Spring height question MG 11
jlaird One spring off and a question Spridgets 1
bluemiata90 rear spring question Triumph 9
martyc Another silly Carb Question [piston spring?!?!?!] MG 3
C Another rear spring question Austin Healey 3
J Spitfire Choke Return Spring Triumph 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
