New midget good news and bad news
regularman
I spent the day cleaning and inspecting it and going through the wiring. I decided to get her running and so, ITS ALIVE! Good news is that the motor seems to run great, I thought it had no clutch but I was wrong it actually has a full pedal. Now for the bad news. I can't get it to go in reverse. I put some brake fluid in the master and managed to get a hint of brakes so I decided to run it up and down my drive. I have never had a 1500 before. Where is reverse supposed to be? I tried all the usual places and I only have the 4 forward gears.
Pictures.
The good side of the car. Its in real good shape just needs some decent paint.
The engine bay. The engine looks and sounds good and everything is there, only some slight surface rust a few places
Drivers side floor pan, no holes but the seat holes, just some surface rust (still junk and dirt in there right now)
Trunk, good shape no rust that I can see(better than my 71 was)
Passenger floor pan much like the driver side
driver lower hinge, looks good in there.
passenger lower hinge, only light rust (still solid)
Underside looks better than I had hoped
The bad part that needs to be fixed (car came with a new sill for this to be welded in)
Unbelievable the previous owner used plastic tubing for the clutch line
This line actually works and has a good pedal but look where they ran it??????????????? Down through a rusted hole in the battery box :lol:
Another shot of the engine (not too shabby)
url]
A poor picture but the dash is in real good shape in this car.
url]
Billm
Kim
I don't have a 1500 but I think that the plastic tube running thru a rusted hole is stock!
BillM
regularman
regularman
Billm said:
Kim
BillM
You know, Bill, I have to cut out that old battery box and weld in some new metal, I just can't believe that poly flow or whatever kind of tubing that is worked for the clutch.
dklawson
The 1500 will have the "single rail" Triumph box. Push the lever across neutral towards the passenger door, LIFT the lever and push it forward towards the dash (parallel to 3rd).
JPSmit
regularman said:
startech47 said:
The plastic line is stock. The irregular rust hole was a round hole with a grommet when new.
Seriously!
Yup. And reverse is up and to the right - but you have to lift the shifter. It's an acquired skill.
regularman
regularman
Wow, I have been lazy and am just now up and having "breakies". That is two here saying lift over and up to the right. I will try that in a few minutes. So, you basically lift up on the shift knob and it should then go into reverse in basically the same place that 5th is in most 5 speeds. I hope that works, I am already tired of pushing that thing backwards.
JPSmit
exactly
Jim_Gruber
He probably got it to work and now can't get it out of reverse. Either that or he went out to go driving and didn't want to come back.
jlaird
Oh well, parts is parts. LOL
AngliaGT Midget on the Evening News! Spridgets 0
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 12
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
