The rear brakes are not letting the wheels turn. The '51 MGTD has been stored for over 30 years and I think the hand brake was set when it was parked. Now the car cannot be pulled forward with any movement of the rear wheels. Pulling it backwards the right rear wheel will rotate slowly and the left rear will move only occasionly. I have soaked everything I can get to behind the drum with PB Blaster and have tried heating the drum to see if it might expand and come off.
What steps should I take to get the drum off and replace the adjuster/wheel cylinder? I am sure someone has had this problem and knows a fix. I sure hope so!
I do believe the transmission is in neutral.
Thanks,
Charlie
Thanks,
Charlie
