Need Help: Oil leak/crankcase pressure
Guapo
I'm new to this board and need help! This past fall I purchased a 1960 Sprite with a 1275 in it. It was recently completely rebuilt by the previous owner (might be on this board: Patrick Casey). He'd driven it less than 500 miles before I purchased it and had no oil leakage issues. What it's doing is it will "puke" oil out the front and back of the engine. The first time it was about a 2/3 of a quart overall. The second time it was maybe a cup. I expect drips but not this. I'm hoping it's something to do with the crankcase pressure as I'm a basic mechanic and not looking forward to having to do major work.
Here is some info on the car (from the PO):
1275 cc Spridget motor with +0.040″ 7cc dished AE/Nural pistons
• Pierce Manifolds 5-port alloy head with stock intake/exhaust valves/valve train
• Competition head gasket, silicone valve cover gasket and bypass hose, stainless steel hose clamps
• Cam reground to mild street profile and lifters resurfaced (DeLong Cams spec)
• Compression ratio 10.3:1. Runs well on ethanol-free 89 octane gasoline
• New Tri-metal bearings (mains and rods), new cam/crankshaft thrust washers
• New alloy rear engine plate
• ARP bolts/studs (mains, rods, head, and flywheel)
• New Iwis double row timing chain
• New water pump, new star drive oil pump
• Gerard’s lip style rear main crankshaft seal
• Lower end balanced
• Spin-on oil filter – Mahle OC21
• Distributor rebuilt by Advanced Distributors—advance curve to match cam
• Champion RA8HC plugs
• New fuel tank with POR sealant and new sending unit
• New long center branch exhaust manifold with 1.5″ diameter exhaust pipe
• Cherry Bomb silencer (from UK)
• Rebuilt SU HS2 carbs with Cooper MKI style pancake air filters
• New Fidanza alloy flywheel, new Borg & Beck clutch/disc., release bearing/clips
• Braided stainless steel remote clutch slave cylinder hose and speed bleeder
• Original style downflow radiator with kevlar hoses, stainless steel clamps
• Valvoline VR-1 20-50 wt engine oil
You can see in the pictures that the timing chain canister is vented to the carbs. The valve cover vent is capped. Should I be venting this differently? Oh, and the oil cap is vented. Any help and/or insight would be greatly appreciated.
Gerard
What about the 90 degree fitting in the middle of the manifold? I assume that's plugged since it wouldn't run very well otherwise (if at all), so just confirming. Sounds like you still have too much internal pressure and you'd probably be better off using a Smith's PCV off the manifold, rather than the vacuum from the carbs. I'm not sure why things wold suddenly change, but he higher compression pistons may create more pressure than can be alleviated by the draw from the carbs.
G
Guapo
The 90 degree fitting is plugged. If I try what you mention, what do I do to the openings on the carbs...plug them? The Smith's PCV valve, do I buy that from Moss? Sorry...new to all of this.
Gerard
Either find a good used one or the one from Moss. Use a short piece of hose to bridge the two ports on the carbs. I can't guarantee it will be a cure, but it's the first thing I would try. Have you had any feedback from Patrick?
Something to check: Remove the oil filler cap with the engine running and place the palm of your hand over the opening. Is the air rushing out or is there a vacuum?
G
Guapo
Patrick has been great; though, he's not convinced it's crankcase pressure. I wanted to get others to chime in...the council of many. I'll start her up and try the oil cap opening thing and check back in.
Thinking out loud here ... new engine ... could be something leaking around a gasket (timing cover or oil pan). Or maybe the front seal was not centered with the timing cover was installed.
G
Guapo
Just checked and when I remove the oil filler cap and put my hand over the opening there is a vacuum.
Ok ... start checking for loose oil pan bolts and timing cover bolts.
G
Guapo
Question...with the oil filler opening pulling a vacuum does that mean that it's not a crankcase pressure issue?
If it is pulling vacuum at the filler, then crankcase pressure is probably not your problem. UNLESS there is significant ring blow-by at higher rpms.
G
Guapo
I just checked for loose bolts. None were loose but needed a bit of tightening. I just snugged them up. Hard as **** to get to the timing chain bolts. I've never had it "puke" while on the lift. It's always happened while out driving, but in the tightening I just did, it showed zero seepage when started and warmed up. I'll try and get out in it this week if it's dry enough. Trevor, I'm in Floyds Knobs, so I have the same weather you do. Thanks for the input. I'll report back once I get a chance to drive it and see how she does. I'm also open to further input.
At 500 miles on the engine I would think that the rings would have bedded in by now. Is Patrick Casey a local guy?
smaceng
So what happens when you travel down a long grade in a lower gear....lots of vacuum....do you get lots of smoke out the exhaust? If so, that could mean the rings have not set and the high compression is blowing the oil out the seals.
Scott in CA
wgtolhurst
The clue seems to be that the engine "pucks" a cupful or more of oil quickly, almost like a chamber filling up.
Not overfilling it, are you??
Good luck, I'm sure its something simple, seems like a well thought out engine .
G
Guapo
I haven't noticed an smoke out of the exhaust; though, next dry day, I'll go down a long grade in a lower gear and double check.
G
Guapo
I don't believe I am; though, I've only topped it off once. The first time it occurred, it was with the oil fill from the previous owner (it arrived with the oil level at the full mark on the dipstick). I topped it off to the full mark (took about 2/3 of a quart). The second time it was a cup or less. I haven't topped since the second occurrence.
Jim_Gruber
And Oil Pan Bolts need to be torqued at like 7 lbs or you will deform and dimple pan and create leaks. See Gerard's Web Site for how PCV is supposed to be routed.
SD Bugeye
Ok your experiencing way... more oil than me but may be connected.
mine would leave a quarter sized drop of oil every time you shut the car off.
mind you start it up and idle till the cows come home not a drop.
Shut it off quarter size drop
this came from the front of The engine but not the front seal it was from the timing cover .
tightened up the cover and it has pretty much stopped it must sling oil when it's running to a spot that leaks but vacuum is enough to keep it in the case u till it stops.
Im guessing a puddle between the timing cover and the block around the crank -timing gear .
maybe same sort of deal
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
C Oil Seal Removal from Idler Arm? Need Help Austin Healey 4
Gliderman8 Drip, drip, drip... NEED HELP WITH FRONT OIL SEAL Triumph 21
I Need help hooking up oil gauge lines Spridgets 5
Dadandson Need Oil Pump help Spridgets 8
Bruce_B Need help with oil pressure on startup of engine!! Spridgets 8
F TR6 Need help w/TR6 oil cooler install... Triumph 16
P have a BIG oil leak...need help Triumph 2
rodesmg oil seal on timing cover== need help Spridgets 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
